XTS5000 Question
KOSMOKRAMER
Baltimore, MD
After turning on the radio does the LED on top turn green and go out? If not check the contacts on the battery connector where they make contact with the rf board. Sometimes they are pushed down into the grey plastic and don't make good contact. Also remember oil from your fingertips can cause issues with any of the contacts inside the radio. Rubbing alcohol and a lint free cloth will help. Another thing is to make sure the front cover flex connector is seated properly into the circuit board. If you can measure the current draw when you turn on the radio, you should see around 80 mA.
mfn002
Bryan, Texas
I opened up the radio BECAUSE it stopped working. As far as the contact issue goes, I pulled them up pretty far to make sure they were contacting the circuit board. I'm getting power everywhere; it just won't seem to power up. The LED does not go on...NOTHING. It is very strange. Is it possibile it could have thought I was doing something bad to it and I was tampering with it and thus locked up in some sort of "safe mode"? Could it have something to do with the key I kept seeing before it failed?
I measured the current drain by voltage and it showed a drain of approximately 1 volt or less.
I did notice there was some sort of greasy white substance in the radio, could this be a problem?
KOSMOKRAMER
Baltimore, MD
Key Fail as posted earlier won't cause the radio to stop working. You can remove the secure module from the radio if you want to eliminate it as a possible short. After doing that and provided the radio powers up you will see a FL 09/10 message which means the radio is programmed for a secure module but the radio cannot see it. What happens if you push the PTT button and orange button at the same time while turning on the radio?
mfn002
Bryan, Texas
Nothing...still dead. I think it might have something to do with that circuit board underneath the metal cover. Was that the original problem with the radio?
How much would you want for a working one that's VHF (the board, that is)?
mfn002
Bryan, Texas
Problem Resolved!!!
RF Board is shot. Kosmokramer is going to send me a new one.
SKEYGEN
mfn002 said:
JUST IN CASE NO ONE READ THROUGH THIS THREAD, THIS RADIO IS VHF CONVENTIONAL, NOT 800.
FYI, trunking is not limited to 800MHz. There are heaps of systems all over the world on VHF, UHF, 800MHz and 900MHz.
