Yaesu: Yaesu Ft-991A Problem
kb9hgi
West Central IL
I have a Yaesu FT-991A and its been working fine went to turn it on 2 days ago it tx and rx but when I push the F/M-List button it does not work. I can not get into the F menu The Fast and Lock buttons does not work either. Everything else seems to work I just can not get into the F menu I tried unplugging eveything did full reset and still no good. Won't even read the firmware version when I push A=B & A/B when powering on. I did have it working once last night when I held the F button and powered it on but that trick won't work today. Anyone have a Idea before I ship it to Yaesu?
n5ims
Try to call their support phone number and talk to them about your issue. They might be able to diagnose the issue over the phone and if not can probably give you an RMA number that you probably should get to send it in for repair anyway even though it may not be required. Welcome to Yaesu.com
Contact us (714)827-7600
between 8AM – 5PM PST
Parts Department option 4
Customer
Service option 5
Technical
Support option 8
AB4BF
EM93cs
Check your supply voltage/power supply first before calling. Should be at least 13.4 VDC with no load. Check all the connections from the power supply to the funky connector at the radio. Maybe, just maybe, low voltage. If all checks good, call Yaesu, they have very good support. Good luck!!
kb9hgi
West Central IL
i called Yaesu Today told me what to do and did not work. So he said I'm affraid your going to have to ship it to us. Just my luck. I just got her all boxed up and will ship in the morning
