I had this problem before but for some reason I can't recall how to "fix it". I have ZERO audio coming out of the FT1D, not even when I press the "mon" button. I used CHIRP to program the radio because the RT-Systems software doesn't want to see the SCU-19 cable.
I do have APRS running on 9600kbps, but that shouldn't be an issue as that is on the B Band and I'm trying to operate on the A Band.
Anyone have any suggestions?
Regards,
-Frank C.
Have you checked your volume levels? The FT1D has notoriously low audio even when everything is working properly. I have to routinely run mine up to 25 or higher to hear anything out of the internal speaker.
If you already have the RT Systems software, you can use it to write programming to a MicroSD card in your computer, then insert it into the radio and read from it. That's how I program mine.
I was told that for APRS to operate properly, the radio has to be set to 1200 baud, not 9600.
Have you check out Yaesu website? They have their own software that you can download. It works well.
The original version of the ADMS-6 programming software from Yaesu was junk. One of the members of my club had problems with it and when he called Yaesu, the tech told him not to bother; that it was something they cobbled together in a hurry. There may be an updated version, but I don't trust it.
