I am still a Baofeng fanboy.
You would be amazed at what polyurethanes and other clear coatings along with some elbow grease can do. So technically a turd can be polished. In my other hobbies, taking a turd (like a Baofeng) and making it useful or better is the fun. Just buying a high end widget that is perfect is boring. I mean look at a TRTL-SDR dongle. It is a turd for what it was originally designed for, but when some curious nerd found another use for it, wow, it is almost limitless what they can do.You can't polish a turd.
Second reference to the cheap RTL SDRs in this thread. I think they are great. However it's still not apples to apples as my RTL doesn't transmit and affect other people. My choice in cheap SDR only affects me. Your choice in horrible transmitters affects anyone close enough to be interfered with. It's an affront to the rules.You would be amazed at what polyurethanes and other clear coatings along with some elbow grease can do. So technically a turd can be polished. In my other hobbies, taking a turd (like a Baofeng) and making it useful or better is the fun. Just buying a high end widget that is perfect is boring. I mean look at a TRTL-SDR dongle. It is a turd for what it was originally designed for, but when some curious nerd found another use for it, wow, it is almost limitless what they can do.
Stop bashing Baofengs, use that technology to create something better.
They pretty much bash themselves at this point. We just point and snicker where appropriate.Stop bashing Baofengs, use that technology to create something better.
The bigger issue, in my opinion, is the myth that an inexpensive handheld is an amateur radio station. In the literal sense, it is. But, you can't communicate very far on simplex with a handheld and if you are using a handheld to access repeaters, your signal will often be noisy and inconsistent.If the cost of a radio is keeping someone out of the hobby, then by all means, a Baofeng is the right tool for the job.
My understanding on the Baofeng UV-5G is it is the same radio as the UV-5R but has different firmware to prevent it from TX outside the GMRS channels. The UV-5R from what I have read can be unlocked and made to TX on the GMRS channels but that would be against the FCC rules. I would love to re-run my simple test using a UV-5R on the exact same frequency as the Yaesu FT-60R but I do not have one to test. While it is true it was not an apple to apple test I did the best I could to test both radios as close to even as I could get. Still think it was fun and I learned a lot.There's one big flaw in the arguments being presented here. The OP is comparing a radio designed and built for the amateur service against one designed and built for GMRS. That's like comparing apples and oranges. The only thing apples and oranges have in common is that they are fruits. The only thing a Yaesu FT-60 and a GMRS Baofeng have in common is that they are radios. They operate in different services and don't even fall under the same set of regulations. The regulations quoted above are from Part 97, which applies to the amateur service. They, including 97.307(c), DO NOT apply to GMRS or the radios used there. GMRS has it's own set of regulations laid out under 47 C.F.R, Part 95 Subpart E.
The leap from a $25 handheld with a rubber duck antenna to a 2m mobile with power supply with outside antenna is huge and relatively expensive. Wearing our mentor hats we, in my opinion, need to help new hams figure out ways to bridge that gap even if it's only using that handheld with a J-pole antenna hanging from a wall inside their apartment.
No offense taken. We've got some good discussion going on here and that's the whole idea. I'm not seeing any of the negativity that' shows up these days.The implication in that statement is that the Yaesu is the Cadillac and that the only difference between the two is fit/finish/luxury/options and they both will get you where you want to go.
However the reality here is that the Yaesu is the Yugo, and the BaoTurd is something which should never get cleared by the NHTSA for travel on US roads. Because the latter is unsafe to those around it.
"It works, doesn't it?" is a statement used by the ignorant who don't realize that there is more to the equation. You don't know what you don't know is a phrase that comes to mind. But what many who would argue in favor of the BingBong do know is their ego and the inability to admit fault at subjects they are unfamiliar with. Thus we end up with people who will 'die on this hill' defending their precious garbage.
K6CPO, this isn't in any way a personal attack on you, but a generalization based on similar statements made by people trying to compare apples to particle physics.
Not bashing, stating the truth. I realize that isn't in fashion today, but FACT remains these radios are subpar garbage, based on cheap consumer grade toy ICs and do more harm than good: aside from sounding like mumbling low audio turds on ham radio bands, they are responsible for much unauthorized operation across RF spectrum by consumers who procure off Chinazon thinking they are buying "licensee free walkie-talkies" when they are anything but.You would be amazed at what polyurethanes and other clear coatings along with some elbow grease can do. So technically a turd can be polished. In my other hobbies, taking a turd (like a Baofeng) and making it useful or better is the fun. Just buying a high end widget that is perfect is boring. I mean look at a TRTL-SDR dongle. It is a turd for what it was originally designed for, but when some curious nerd found another use for it, wow, it is almost limitless what they can do.
You have me rolling on the floor, might be a bit harsh but funnyThis junk should be considered contraband like other counterfeit Chinese feces and subject to confiscation by law enforcement, then destroyed.
THIS. I personally have already found two instances of unlicensed operation using CCRs. Both revolve around a certain park/campground/concert venue. A touring artist's crew had UV5Rs ON THE LOCAL SHERIFFS FREQUENCY but luckily with the wrong PL and the Sheriff's office already switched to the state trunked system for their primary operations. Then later I found out the park staff bought new Retevis radios to upgrade from FRS and they are all on 146/147MHz freqs. The only saving grace may be that it is in the middle of nowhere and probably only ~2W so they must not be interfering with any local hams....they are responsible for much unauthorized operation across RF spectrum by consumers who procure off Chinazon thinking they are buying "licensee free walkie-talkies" when they are anything but.
And I'll give you one guess where they got the frequency/PL info from. I'll wait…..
Pick me pick me!! I know this one!!!
The 1990 edition of "Police Call" for your area??
Sorry, couldn't resist. But all kidding aside, your point is well taken. Sadly that genie was let out of the bottle years ago, and even if the FCC waved their magic wand and stopped all future imports of wide-open CCRs today, the damage cannot be undone. Requiring them to be imported locked down to just ham frequencies was a good step, but the fact that it takes about 5 minutes to unlock them (including the time to search the Internet and find the magic button sequence) kind of negates that.
This is scary. It's no different with BDA/DAS, and not just for public safety/part 90. Stupid consumers turn to Chinazon, where a plethora of RF emitting devices are for sale from dubious sources adding to the noise floor, causing debilitating interference, and compounding the problem. The FCC is too busy pandering to the telecom cartels, and enforcement resources just are not there.THIS. I personally have already found two instances of unlicensed operation using CCRs. Both revolve around a certain park/campground/concert venue. A touring artist's crew had UV5Rs ON THE LOCAL SHERIFFS FREQUENCY but luckily with the wrong PL and the Sheriff's office already switched to the state trunked system for their primary operations. Then later I found out the park staff bought new Retevis radios to upgrade from FRS and they are all on 146/147MHz freqs. The only saving grace may be that it is in the middle of nowhere and probably only ~2W so they must not be interfering with any local hams.
One of my favorites is the karaoke mics from eBAY/Amazon or even local stores in some cases. I'd venture to guess they are more prevalent than people realize, but the illegal carrier pops up for a few hours on Saturday night and then it's gone until the next party. Had an eye opener once with the customer when I listened to the frequency the illegal carrier was one and we heard "Don't break my heart, my achy breaky heart". The customer had no idea a wireless mic could do this.This is scary. It's no different with BDA/DAS, and not just for public safety/part 90. Stupid consumers turn to Chinazon, where a plethora of RF emitting devices are for sale from dubious sources adding to the noise floor, causing debilitating interference, and compounding the problem. The FCC is too busy pandering to the telecom cartels, and enforcement resources just are not there.
Joe stupid consumer wants "long range walkie-talkies" and orders up some Baoturds from Chinazon. Has no idea nor cares that he/she may be interfering with someone else whether it be police, fire, EMS, animal control or Joe the Plumber who is actually licensed. Jenny consumer's cellphone doesn't work in her house, so off to Chinazon to buy a "booster". Jenny has no idea that this class A broadband amp is as much of a spurious emitting POS as that Boaturd made in the same factory, it makes her phone show more "bars" so it must be working, right? She has no idea that since turning this road apple on, a ton of illegal carriers are now present on the uplink of a nearby RFSS for the 700/800MHz PS system in her area and the cops can't talk. She has no idea that AT&T/T-Mo/VZW are now seeing broadband noise clobbering LTE on a nearby site.
Common denominator here are junkpile devices + dumas consumers = tons of HASH AND TRASH, illegal operation, unintentional jamming, and job security for us certified in RFIM.
Baoturds and their low TX deviation, pathetic receiver front ends, and garbage pail performance are only the beginning.
