ubernerdsteve
- Joined
- Sep 5, 2016
- Messages
- 2
Hi All,
I've attempted to find a similar problem through various Google searches but am always open to links if someone thinks this is already answered... I believe I discovered a similar problem in one other discussion but not sure it was ever answered.
I have an FT-60R that has functioned for years without issue. The radio sat for a couple of years, I recharged it, and when I turned it on the radio was stuck on one of my programmed channels. The lock indicator was on, I was able to push and hold 6 and remove the lock indicator but the radio still functioned like it was locked - lights come on when I push buttons or turn the scroll knob but it stays put on the existing frequency.
I then performed an allreset -> shut radio off, held moni button scrolled using knob to all reset, push FW, TX bar lights up, radio beeps and restarts. I can still continue to do this; however, the only thing that has changed now is that my memory is whiped out, the lock doesn't initially appear on the screen but the radio is still locked out.
At this point if I just turn it on it displays [ FM 430.000 Save] (the save is solid) and buttons do nothing but other than make the backlight come up. TX does nothing other than if I hold it long enough I can make the save flash, pushing FW makes it stop flashing.
Additionally I can get into the reset mode (not sure the official name for it) and change it to U-only or V-Only or M-Only. That does change what is displayed on the screen but I'm still equally stuck (V-Only displays 144.000 instead and M-Only Displays Mem001).
I do have reason to believe this all happened from the power supply. It doesn't seem to be functioning right. I have gotten another power supply, completely discharged battery and recharged with new supply.
I don't there is some mode I could throw it into that wouldn't be reset by one of the reset options so I don't presume I am that lucky but it's worth a shot if anyone has suggestions. I have pulled apart the radio and find nothing that would indicate a hardware failure - no smell, no obviously failed components or damaged traces.
Any suggestions? Is it possible it's a firmware issue, any way to reload the firmware? Radio is not under warranty so I'm not worried about voiding warranty with your suggestions. This would be a lot less frustrating if the radio appeared to be totally bricked but it still performs basic functions, I can still get into the reset menu and that doesn't seem to be an issue...that is why I lean to firmware; not sure if the radio has a separate eeprom for the reset menu but that's what the symptoms seem to me to be through I am far from an expert with this radio.
Thanks in advance.
Steve
Thanks in advance.
Steve
