PewPewChris
Noob
I get FM radio stations on the HT clear as a bell. I'm using the larger/folding ABBREE antenna. I don't feel like being inside versus going outside is really doing much.
I wonder if the problem might be your antenna.Ok, I take that back, I just got a brief voice of "slight chance of showers" on the NOAA frequency
Cheap Chinese Radios (CCRs) do have a lot to be desired. But I'm not convinced that that is the problem.<snip> I'm imagining, while there is probably a lot of user error ongoing at the moment, a $30 HT isn't really going to cut it if I want to actually connect to something from my house.
The Yaesu FT-991A is a very nice radio. I have a few friends that have that model. They are super pleased with it. As for having a Ham Radio Outlet nearby, you are one lucky ham! One of the ultimate "candy" stores! See you in the Georgia forum... 73, Dave K4EET<snip>
The radio I've had my eye on is the Yaesu FT-991A. I've got a Ham Outlet store without 45 minutes of my house. I figured once I have my tech license, I'll make a run up there and throw down some $$$.
I'll be doing as much research as I can ahead of time...but I'm hoping the folks at the store can be my guide. My luck, I'll spend $2,000 on equipment, get it setup and then realize I'm in some amateur radio black hole in my neighborhood lolThe Yaesu FT-991A is a very nice radio. I have a few friends that have that model. They are super pleased with it. As for having a Ham Radio Outlet nearby, you are one lucky ham! One of the ultimate "candy" stores! See you in the Georgia forum... 73, Dave K4EET
RepeaterBook is very wrong. Lots of paper repeaters and Georgia trustee omits relevant information. The WC4RAV VHF repeater is P25 full time. So yeah, O/P's CCR isn't going to work. The UHF analog is currently offline. I know, I am the trustee of both.Cheap Chinese Radios (CCRs) do have a lot to be desired. But I'm not convinced that that is the problem.
The 147.535 MHz repeater (WC4RAV in Marietta) appears to be a digital repeater with a non-standard offset (-0.940 MHz). If it is in-fact transmitting digital 100% of the time, with your PL tone (CTCSS) blank (carrier squelch), you should be able to hear low volume "noise". I say low volume because it is a "narrowbanded" repeater according to the RepeaterBook.com database (which has been known to be wrong a time or two). RepeaterBook is dependent on input from the repeater's custodian(s) and then keeping that information up-to-date if changes are made.
The interesting thing was when you heard the morse code. If the repeater ID comes through it could simply be nobody is talking? \
Specifically, the Find a Club search tool is here: Search for ARRL Affiliated Clubs2. Find a local ARRL club at ARRL - Home
The only problem with that is that K4EET was having a conversation with someone on that repeater, I never heard any of it...Reading through this thread, that's what I was thinking.
Many ham repeaters are very quiet and it's not uncommon to not hearing anything on them. If you hear the Morse code ID, then you are receiving the repeater. There just may not be anyone talking.
