Zello/Network Radios Interface
AK4FD
Catawba, NC
Does anyone here use Zello or some other type of Network Radio with an interface or some sort-of link? I am trying to find a way to link my Icom 7100 radio to my Inrico T320 Zello radio so my Skywarn severe weather nets can be broadcasted over my Zello channel... Please tell me how you have it set up. Thanks in advance.
AK4FD
Catawba, NC
My son has used a Signal Link USB, computer running Zello and a mobile radio to interface Zello to ham radio before. If you need more details on this method, IM me and I'll ask him to write it up.
Actually, yes if you don’t mind. I have a Signal Link USB device as well so that would be perfect for me to do.
lynchy135
I second that! I’d love a write up if possible, I have an idea for a POC
AK4FD
Catawba, NC
My setup doesn’t need to be too fancy, I really only need a 1-way path. I am wanting to broadcast my Skywarn severe weather Nets over to my Skywarn Zello channel for my Spotter Group I run, but I don’t need them to talk back to ham radio, it’s just for them to hear what’s going on the ham repeater when I’m doing the Net.
Citywide173
Attleboro, MA
Get a cheap usb sound card like this one, feed the audio from your radio as your microphone source in zello and set it to VOX and tweak the trigger point. This way, you won't lose your mic, speakers, etc from the everyday things you do with your computer.
AK4FD
Catawba, NC
Funny you say that, 15 minutes ago I ordered one on Amazon that will be here Tuesday: Sound Blaster USB Sound Card, so hopefully that will fix the issue...
wwhitby
Autauga County, Alabama
My son also runs an Echolink node, so what he did for Zello is similar to Echolink.
This is what my son said:
You need a mobile (or HT) radio, a Windows PC, a SignaLink, and the cables for the radio to SignaLink interface.
1) The SignaLink USB is the interface between the computer and radio. The SignaLink has to be configured per the instruction on Tigertronic's website (i.e., move internal jumpers), and then use the SignaLinc's cables to attach the SignaLink to the radio. The SignaLink is hooked up to the computer with a USB cable.
2) The Zello software runs on a Windows PC. Within the Zello program, you have to go in and select the sound card that will be the Signalinc in the settings.
3) If you want to transmit from a mobile radio to Zello, you have to enable "Vox on Receive" within Zello (for audio in.) Since the soundcard is selected in settings, the Signalinc will trigger the PTT on the mobile radio and send the audio from Zello to the mobile radio.
4) My son also said to disable (mute) all Windows sounds, since those will be transmitted as well.
He said he would be glad to help, so if anyone has any questions, please respond to this post and he will help out.
deputyoz
Onset Ma.
Good morning, is he available for questions
