Zetron Model 735
Sputnik1
Kettering - Northants - UK
Hello everyone.....
not sure if i should be posting this elsewhere but I'm hoping that some M'rola fans may be able to guide me......
i have an issue with a Zetron 735 teleconnect
can anyone guide me into how the contact lists embedded in the unit can be edited ?
any guidance would be gratefully appreciated and acknowledged
thanks in advance
Sputnik
ramal121
Lots and lots of watts
Calif Whine Country
Like a lot of Zetron products you can connect a PC and access via RS-232 to the internal menu system using PuTTY, Hyperterminal, etc.
Do you have the manual?
Sputnik1
Hello
thanks for reply
client has PuTTY available on site but no manual
attached screen shot sent through
Teleconnect works absolutely perfectly until you try to access mobile ID numbers higher than 55
the 735 standard has a 99 user id capacity so i am assuming that the unit only included ids 01 thru 55
when originally programmed
now its time to add extra users but where to add the magic numbers without wiping / out corrupting existing settings
5T - CCIR
any guidance appreciated
regds
M
