So I have both a SDS100 & SDS200 That are both programmed the same. and connected to the same outdoor antenna.
All service types are selected.
I set up a One Channel DMR System to listen to my OpenSpot2 Hotspot (Named OpenSpot).
While scanning a few FL, and there is activity on my Openspot, neither scanner will stop on the OpenSpot and play the DMR audio (I do see the activity on signal strength)
If I hold the SYSTEM on OpenSpot, the DMR traffic does come thru properly.
I have both Unit ID's and TGID programmed.
Why are the scanners missing while in scan mode?
