no color code showing
I put a single site DMR in and hear audio, get TG and user IDs and see slot 1 indicated but no color code.
Any ideas? It's 7K60FXD and E so it's probably Trbo.
436 with 1.25.00 firmware, didn't see one before the upgrade on this system but have seen CCs on other systems with older firmware versions.
Ubbe
Stockholm, Sweden
A DMR transmitter must send a color code, you can't skip that function.
Is it a weak station, maybe bad reception due to simulcast?
On the 536 you can see the data errors by pushing function and then the vol dial and as long as the F is lit you can turn the dial and adjust the threshold. Maybe the 436 also have some way of displaying data error rate.
/Ubbe
Single site 4.75 miles at 451 MHz, my calculation says I should see about -55 dBm assuming 100' of 7/8" tx line and a 3 dB antenna for a 45 Watt xmtr. I'll put the spec an on it tomorrow to see how close I am.
I might program my radio to their freq and put a CC in each channel and scan to see what they are using.
