rleonard10
I recently replaced an old external antenna I had connected to the Uniden BCD536HP. When I connect this new antenna the auxiliary audio output jack stops working. I used an existing cable that was running to a different location for my new antenna so it isn't the same cable the old antenna used to connect the scanner and wasn't sure if the cable is bad if that would cause this issue or not? If I disconnect the auxiliary audio output the internal speaker of the scanner works. Has anyone ever heard of this happening?
