highdesert661
Hello. I have searched the forum and found information about using a splitter to run two scanners off of one antenna and from what I understand, doing this causes a db loss.
I have an AntennaCraft ST2 on the roof. What I am wondering is if I can run two coax cables from the antenna? I was planning on attaching a second 300 to 75 Ohm Transformer with coax running to the second scanner. Doing this, there would be two transformers and two coax cables hooked up to a single antenna. Would doing this cause any loss in the reception?
If that will not work, I will need to install a second antenna. Is there any "rule of thumb" about how close two scanner antennas can be located to each other?
Thank you for any suggestions and input.
