chiwititsara
- Joined
- Dec 2, 2015
- Messages
- 23
- Reaction score
- 9
My 12 volt (variable, adjusted to ~13.5v) DC switching power supply just died. I had been using it to power a small 10 watt 2 meter mobile radio for an indoor base station.
I have a few 12 volt starting and deep-cycle lead acid batteries lying around. I also have a spare Battery Tender Jr (0.75 amp max output, seems to float attached battery around 13.4 volts).
This radio consumes well under 1 amp on standby. I rarely transmit or receive but use this radio for occasional simplex contacts.
Would there be any problem running my radio from a 12 volt battery (inside an appropriate battery box) that is also connected 24/7 to the trickle charger?
