148.125 CAP
Marcy57
This was pretty active this morning never really monitored this freq range
148-150 but kinda interesting ! was CAP/ Connecticut Mission Base ...
"This is a training exercise" ...think this is New London? Groton? ..
S9 hr....vy gud cpy...73,s Marcy
ecps92
Taxachusetts
Altho it has been awhile, my experience with CT CAP is the 156.7 is heard when they are using the CT State microwave link to link all the repeaters.
You likely will also find them on 148.1500 at the same time.
you are either hearing Vinegar Hill (Gales Ferry) or Westbrook
Marcy57
Yes 148.150 active also and stronger..
unless I missed it? did not seem at the
same time like a diff. transmission will
have to wait till I cpy agn...thank you
73,s Marcy
Marcy57
148.150 was just active 11.28 am nil on 148.125 at same time...Marcy
ecps92
Taxachusetts
Same PL ? of 156.7 ?
IF I recall, the CT Wing used
One PL for when Linked being 156.7
then each repeater had it's own unique LOCAL PL and/or NAC if used in P25
73,s Marcy
Marcy57
I will check that tomorrow if they are up I missed it...73,s Marcy
Marcy57
I assume? this is CAP net in CT... "Charter Oak 79" "Charter Oak 46"
net contol ....NAC 61F ...they went back and forth from 148.125, 148.150
(156.7) ...Marcy
ecps92
Taxachusetts
Nice find and ReConfirmation of the Mon-Fri 1900 Ne activity
CT CAP when using 156.7 and $61F - appears (previous monitorings) to be linked statewide across all the repeaters (148.1250 and 148.1500)
Also, Federally (as mentioned before) NOT Everything is in the RRDB (nor will it ever be - complete and accurate)
but between the RRDB, RR Wiki and other sources, you might find some nuggets
BTW Civil Air Patrol - The RadioReference Wiki
they seem to have the nets at 1900 Daily for CT
And for your HF monitoring try
(156.7) ...Marcy
Marcy57
Thanks for the info Bill appreciate it, seems they were like
analog and then switched to P25 on 125, I have the HF
part down pretty good been copying them for years on
HF just the VHF part is fairly new to me..thank you
Marcy
