160 Mhz Splinter frequency usage
ai8o
Brachiating Tetrapod
Lexington, NC
I live near a major NSRR yard ( Linwood ).
I hear all sorts of Narrow Band transmissions, but I have yet to hear any activity on the new splinter channels
( the AAR 100 series channels ).
Everything seems to be just narrowbanded, but still on the same Center frequencies.
Has anybody heard any RR usage of these new channels?
burner50
The Third Variable
NC Iowa
They're not in widespread use yet.
They're for future growth, and maybe alleviating some congestion in busier areas (More than just one yard and one railroad. In my area, we have around 8 yards from 6 different railroads, and the busiest interlocking in the country within about 15 miles of each other.
No reason to change yet.
KDOXF
NS has licensed several for use with the Bellevue, Ohio expansion
PJH
None of the railroad radios I have seen have allowed the use of them. The most I have ran across have the NXDN channels enabled. If you try a 100 series number, it just shows up as invalid.
burner50
The Third Variable
NC Iowa
The one I tried allowed it...
I'll try again sometime this week with a few more radios.
PJH
I had a JEM the other day that was "rebanded" but wouldn't allow the 300 series numbers. Someone somewhere isn't doing the universal reprogramming.
FWIW, I have a new spanking portable, no 100 series channels. Just the usual and the NXDN ones. So much for consistency.
Josh
Auburn Hills, Michigan
The CSX yard down near North Baltimore, Ohio uses a splinter channel as an output to a yard repeater they have there.
In Detroit, Conrail is rolling out a yard repeater system that uses some splinter channels as input frequencies.
These repeaters and PL/NXDN whatever operation would require the shop to do the programming and only those that need access to the system would have it programmed into their radio and not everyone's across the board.
burner50
The Third Variable
NC Iowa
Haven't been on a train in almost a month... It's been nice. But haven't had a chance to try this out yet.
