164.925 NAC 200 (East Central FL)
Remington12G
GØT AES?
I have caught some simplex traffic clear and encrypted with similar RID's matching the ATF here in Central KY. $200 is very odd though, has anyone considered ACoE or DoE?
lwvmobile
DSD-FME
Lafayette County, FL
Open to ideas / thoughts / comment.
Just a thought I had, do you have any audio recordings of it? Maybe if you capture enough of it and share it, maybe somebody can solve who it belongs to just by listening in, getting a better idea of what they talk about and when they talk about it, if the radio operators use any identifiers like "Security 9 to Station 1" or similar to state who they are and who they are talking to, anything like that.
edweirdFL
Daytona Beach, FL
Not likely as FLETC is on its own Trunk, with a totally different NAC
What I have heard recently doesn't match the note I had from years in the past. I'm inclined to discount it and only use what I and others have used lately to identify the user(s).
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
the comms are all like what was stated in the original post. I am unwilling to post actual audio clips, sorry.
doug
lwvmobile
DSD-FME
S'all good, I can't blame you, wouldn't want some agency breathing down your neck for listening in and giving you more hassle than what its worth.
Well, after listening to that, I can definitely rule out FDOC. Whoever it is though, they certainly take security/paranoia to the extreme. Actually, sounds like both a security feed and also a maintenance feed with the guy telling him to use WD-40 and a lighter on the wagon tire to put it back on the rim. Its just too bad that lady at the end didn't tell the dude the fax number, that would have probably made something searchable.
batdude
Moderator
I got a lot of recordings today on this freq - but they all ended around 8am or so when the band opening started to fade - so I think this repeater may not be "local" per se ---- could be Tampa or Daytona. When reviewing the recordings today, I also observed several transmissions that were encrypted P25... I have not noticed/observed that before today.
the plot thickens.
zlandmedia
not that florida man
Hillsborough County, FL
Unless I've plugged it into my SDS100 incorrectly (set the channel to P25 with a NAC of 200), I haven't heard anything on this frequency in Thonotosassa, which is slightly northeast of Tampa.
nacsr
Rome,NY
Those comms sounds very similar to Florida DOC/Prison radios. Not the exact terminology I'm accustomed to, but having a 'back gate', 'waste management', outside perimiter 'posts', and 'escorts' being verbally called out for inmates enroute from location A to location B. Usually it would be masked in 10 codes, but plain english is also used a lot.
I agree.Im in Ny but these sound similar to comms I hear from local correctional facilities
jeffdafoe
West Palm Beach, FL
I don't know how relevant it is, but the St Lucie County jail is about a mile from that USDA facility that was previously mentioned.
kf4jhi
Okeechobee, FL
Received some traffic this morning in Okeechobee, mostly about gates and a vendor that will be working outside. I have discone antenna that is about 20’ up. No escort or medical chatter yet. I will keep monitoring.
MegaHertz315
Central/Upstate NY
Is this signal strong in the Tampa area? Just an FYI... NAC 200 is also a NAC used by the USAF. MacDill? Or is that too far from where everyone is hearing this? In NY, we have a base that uses NAC200, in the same band your hearing this on.
batdude
Moderator
my opinion is that this isn't military. I suspect it's a us customs / DHS (etc) warehouse or federal facility somewhere.
ecps92
Taxachusetts
Are you sure about MacDill ?
They were on a UHF TRS using $4A0 not VHF
and have migrated to the 380-400 AF Network using $5xx series NACS
And yes it had been rather strong in Tampa, but then again FL is so FLAT :) sometimes narrowing targets down takes a Long time.
Ranger0034
Clearwater, FL
I was in Orlando on Sunday May 9th 2021, I heard 166.7375 Nac 200 come in on my scanner ENC just 1 or 2 transmissions though
RIVER_5
ÆS LØVER
Getting a mix of AES and Clear traffic on my Portable in Reedy Creek on 166.7375, NAC 200. RSSI is -95 per NX-5200 Meter
RIVER_5
ÆS LØVER
Another mix of AES and Clear traffic. Both 166.7375 and 164.9250 appear to be linked and multi cast. Very week on .7375 on Universal Blvd & McKenna Dr. Very Strong (about -79 on my RSSI Meter) .7375 on Hotel Plaza Blvd near Disney Springs.
