178 miles...???
LIScanner101
Palm City FL
Is it possible?
Is it feasible for me to scan Cape Cod FD (an 800MHz trunked system) from Hicksville NY - a distance of over 175 miles?
I did a mapping of the distance as the crow flies and it looks like most of it is over water.
I assume that if this is at ALL possible I would need a super-high gain Yagi way up and some mega-thick coax - or would it just be impossible under all considerations?
I used to listen to Cape Cod from my camper in Montauk - it's a pretty busy system!
LIScanner101
Palm City FL
Sorry, what's a "band opening"? Is that the same thing as low band skip? My apologies, I'm not being deliberately obtuse, I just don't understand...
Portland, Oregon
I think it may mean that there's no other users in the line of sight (or otherwise receivable) that would interfere. In other words, a clear path in the spectrum.
KB1VLA
South Berwick, ME
Yep, the same principle, except it doesn't happen as regularly as on low band, due to the high frequency. I have monitored the MSP system with a Pro-106 with stock antenna from York County, Maine before.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The best place to get a description of how band openings can occur can be found on the site below...
Tropospheric DX Modes
Nice and simple, without a lot of technical jargon that can more often than not confuse rather than inform.
However it should be noted that on 800 Mhz, it doesn't happen very often, and when it does, it's usually in the dead of summer with a stalled weather front. You are more likely to be able to hear them using any of the numerous online scanners that can be found all over (as well as on our sister site, Broadcastify.com - the Mass. entry is below...
Broadcastify - Massachusetts Live Audio Feeds
and I'd also ask on the Scan New England website about other online feeds...
Massachusetts Statewide
as well as on our own Mass. forum...
HTH...Mike
LIScanner101
Palm City FL
Thanks Mike. Yeah, I know I can always listen in on live feed but half the fun is "hunting down" the signal and having 100% control over what I listen to as opposed to having to be restricted by what the feed allows.
VE3CRO
Tilbury, ON
It is entirely possible to reliably monitor Cape Cod from your location. All that is required (given no rising terrain between you and them) is an antenna mounted on a tower at least 116 feet high. The curvature of the earth is about 8" per mile (7.98" to be more accurate). Direct line of sight would be achieved at very close to 116 feet. No band opening required.
LIScanner101
Palm City FL
That was sarcasm, right? I can't put up a 116' tower.
VE3CRO
Tilbury, ON
No it wasn't sarcasm. You asked if it was at all possible and I answered. I know more than one ham with a 100' tower. Didn't mean to ruffle anyone's feathers. I did want to illustrate how you could figure it out. Cheers.
W8RMH
Feed Provider Since 2012
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.4; en-us; LG-LG855 Build/GRJ22) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
I don't think you'll receive that system that far away just due to the curvature of the earth alone
danham
Cape Cod, MA
You probably already know this, but just in case ... there is no such thing as "Cape Cod FD." We have 15 towns, each of which has one FD and one of which has several "fire district" FDs. They are all on the MA State Police trunk and of course there are interop talk groups as well.
As for working this from 178 miles away -- an interesting challenge. Over the water can help but can be very fickle. There are places here on the Cape itself where portables find themselves in black holes of no signal.
-dan
LIScanner101
Palm City FL
No worries, I was being a little too sensitive about it...! Thanks and I appreciate your input.
LIScanner101
Palm City FL
Yes, I do know, I was just referring to the ones on the Cape colloquially. I used to listen to Barnstable, Mashpee, Cotuit, Hyannis, Sandwich, Yarmouth, Orleans, East Harwich etc etc. It was a great group of FD's because they were always so active (I guess that depends what end of the call you're on!).
-dan
Yeah, I'm almost ready to just admit that it's probably not going to be worth the expense of finding a super-high gain Yagi and pointing it towards MA, and since I can't put up a huge tower then most likely it's not gonna work.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9900; en-US) AppleWebKit/534.11+ (KHTML, like Gecko) Version/7.1.0.523 Mobile Safari/534.11+)
Reliably listening to a Vhf signal at 178miles is next to impossible, never mind 800MHz.
gunmasternd
Fargo,ND
850 MHz Grid paraboilc dish Antenna high gain series | 806-896 MHz , 17- 23dBi
and a preamp? maybe plus you have to mount it about the tree line! that dish would have to be within a couple of degrees of the antenna you want to listen to also.
You would be able to pick it up maybe :) with alot of noise and other Signals.
ridgescan
San Francisco, Ca.
Just to add to the buzzkill here-I have a d130j discone at 50' and the furthest I can get is about 40-50 miles, and that is vhf and uhf. Granted, an omni antenna and more than a few hills in between.
On 800, I can't even get Oakland stuff just across the bay at 10-12 miles.. funny though, I can get San Francisco on 800 in the truck off the Larsen Tribander when I'm in Oakland lol, which shows that hills can kill signals.
I wonder if a tuned yagi pointed dead on toward the desired agency might at least get you in the ballpark?
