2001 Sebring Sedan
_Jerry_
I already have the antenna and scanner mounted, but I want to power it from the battery. I currently have it spliced from the fm radio power.
1) Is there an advantage from running it from the battery as opposed to the scanner?
2) If I do run it from the battery, would there be a way to have the scanner cut off automatically when I turn the engine off?
The scanner I have installed is a patrolman pro 2025. Old I know, but it fits under the radio so it's out of the way.
cpuerror
Ontario, Canada
Most people recommend running both the + and - from the battery because it reduces noise esp on low bands.Be sure you fuse both wires at the battery. You can make it switch on and off with the key by splicing in a relay.
