Let's see how well the camera on my Palm Centro works! Installed are the following;
PSR-500 monitoring everything connected to a mag mount VHF-High antenna;
PRO-96 on Suffolk TRS connected to an 800 mHz mag mount antenna;
Garmin 330 GPS;
Delphi MyFi xm2go;
iPod 80;
HT1250 connected to an Antennex UHF High Gain antenna.
I tried to get close-ups of the install. I'm utilizing seat bolt mounts from Arkon for the PSR-500 and the xm, and a close-out RS cellphone mount for the iPod (which doubles as the phone mount when the iPod is not in use). The HT1250 and PRO-96 are sitting in the front cupholders. Power is tapped from underneath the center console off an ACC hot line. There is NO noise, the power and ground lines are soldered, assuring good connections. The VHF-High antenna is a temporary fix, since my RS mag mount broke http://www.radioreference.com/forums/showthread.php?t=114003 and I have yet to replace it. I'm glad to share my install, and I hope it inspires. Here are the first 5 pix.
Garmin 330 GPS;
Delphi MyFi xm2go;
iPod 80;
