2023 MOSWIN Sites/Talkgroups
semo
North Dunklin County, Missouri
It appears site 3.57 is online in an unknown location to me. User ID 92444 (Dunklin County) is being denied. No users or neighbors yet. NAC is 1CF.
769.1937 CC
769.44375 SCC
770.44375 WPTZ785
jtimblin1
Florissant, MO
Just set up a calls feed for Weldon Spring, was surprised to get Washington Fire/PD and unencrypted SLPD traffic. Let me know if there are any issues you find or have any suggestions for improvements.
Jwandz29
Leadington, MO
I am no longer hearing the MOSWIN channels on my Uniden Bearcat SDS100 it has all upgrades and the db was updated recently I live in St. Francois county. Has anything changed? What could I be doing wrong?
mgolden2
Kansas City area
I believe it said what scanner he is using...................
"I am no longer hearing the MOSWIN channels on my Uniden Bearcat SDS100"
scanman1958
St. Louis
Try programming a couple neighboring sites to see if you can receive them. Also make sure you didn't accidently avoid any channels for the site you have programmed. Those SDS scanners are tricky.
west-pac
MOSWIN site 1.2 is booming into northeast Indiana this morning; 351 miles.
Here is some updated info about the site that needs to be confirmed and submitted.
Freq: 154.920 is a Control Channel. It's mentioned on the site page, but it's not highlighted as a CC.
FREQ: 152.585 is a Voice Channel. It's not listed.
The neighbor list shows site 3.24 as a neighbor. I don't show 3.24 as a neighbor. 3.34 is a neighbor, but it's not listed, so that 3.24 was likely a typo.
SWMORadios
Polk County, Mo
Did you submit the info? I did some checking and it matches a mlawin frequency sheet I have from a couple years ago. According to the sheet 154.92 is the primary control. The other channel is channel 5 on the site. Good catch and feel free to submit.
west-pac
No, I did not submit it; hence the reason I said: "Here is some updated info about the site that needs to be confirmed and submitted."
If I was going to submit it I would have just submitted it without posting about it.
Thunderbolt
Global Database Administrator
Ann Arbor, Michigan
769.1937 CC
769.44375 SCC
770.44375 WPTZ785
At one time they were talking about adding a new site near Campbell. I wonder if this is it?
73's
Ron
west-pac
73's
Ron
The Gainsville site has all the same CC freqs, and is site 3.47. I've seen DSD+ populate fields incorrectly when I was switching towers/radio signals. I'd ask that guy to go check that CC again and see if it will populate 3 5 7 again.
baretta29
Maryville, Missouri
Site 93 769.19375 is a Neighbor to Site 37 Renick / Clark.
193,"T015D",1ce,"01-1150",769.19375,"" Failed but Current
Site 84 773.05625 is Neighbor to Site 28 Avalon
184,"T0154",1ce,"01-1768",773.05625,""
drbeede
Gatewood,Missouri
Post conversations for 2023 here.
I have a question about the MOSWIN Alton tower site, whenever I go into analyze on my SDS200 there is no data being received from this tower site, has good signal but no data from the control channels, I do not have this issue with the surrounding sites like Ripley County, Van Buren, Poplar Bluff, and a couple other sites in range no issues. Anyone have any idea why there is no data being sent from the control channels on the Alton site?
west-pac
Did you try the other Control Channel?
