2024 Nascar
Wonder if there is a way to convert these to .hpe for the Sentinel Software.
There are no short cuts, best option is copy and paste or use a program that allows you to export to CSV format.
On a side note, anyone figured out how to extract the signal RE puts off at the track? Would love to have an easy way to get them for my BCD436HP and my SDS100.
Once someone figures it out (though technically it is theft of service) it wouldn't be an easy process, as you would need a laptop, SDR dongle and software to decode the signal, then you'd need to decode the signal and convert to CSV format, then change to a format your scanner or software would allow you to import.
Oh yeah, and you'd need to be close enough to receive the signal, the track parking lot would probably be too far away, so you have to take all this gear through security and lug it around all day.
JCar24
Here are some sentinel files I set up last year. I set them up with number tags. To use, push "channel" to hold on any channel. Then hit .. as in dot dot, then the car number. Then hit " channel" again to go to the car number. An added bonus to using this is the ability to the hit "dept" to scan all frequencies associated to that car. I tested this setup at Richmond from the camper grounds. It seemed to work pretty well. Hope this can help.
  • nascar hpes.zip
evilbrad
My head makes a bad antenna
I have a video of the ota signal received on 460.00O. I don't recall a single event were I couldn't find OTA in parking lot. Now the fan vision/kangaroo wasn't well
evilbrad
Milw Mile Truck qualifying day. 8-24
454.000
450.1375
1625 (155)
2375 (162)
3375
3625
4875 (311)
5000
6375
6625
The12tman
How do i get Permissions to download the frequencies? it will not allow me.
The12tman
Are all of these fz up to date with the Atlanta race coming up this weekend?
JCar24
Latest bc125at file updated with the latest racing radio frequencies
Banks 1-4 CUP
Banks 5-8 XFINITY
Banks 9,10 TRUCKS RE style ( turning dial to find backups)
  • 24Nascar.zip
Banks 1-4 CUP
Banks 5-8 XFINITY
Attending my first race Oct 12th in Charlotte, NASCAR Xfinity, thanks for this list. Should I take my computer and SDR, in case changes to programming is needed? Any other suggestions you can make for my first race?
jeepsandradios
East of the Mississippi
Pretty much the stuff posted is accurate for race teams. The only ones that may change are a few truck teams that bounce thru drivers but normally solid. Cup and Xfinity is solid list. CMS security and local comms are in the wiki already and are mostly accurate. I really only listen to security for storm stuff. It will be a good weekend. I rarely monitor the viper stuff but its active on race days.
Definately want a headset and not jsut earbuds or something. I run dual radios but wife likes the plain old standard behind head set. That way she can wear her hat.
JCar24
For the bc125at , I would recommend getting an inline amplifier for your headset(s). The boostaroo https://www.amazon.com/Upbeat-Audio...1&psc=1&mcid=4f7f411e8bc63a17841a28d1e451266c or the amplifier from Racing Electronics are good choices.
You can search from 450.00 thru 455.00 on your scanner for the active tv frequency.
Have a good race, and let us know how the file worked out.
Jack
This is the headset I will be using, worked great earlier this year at Cherry Point Airshow with the loud fighter jets. For now I'll pass on the inline amp since I really don't plan on going to any other races right now, if things change I might reconsider.
Thanks to you both for your suggestions and input.
evilbrad
I believe those are koss made? Work pretty well. I have a insane amount of those type Koss/other similar..I have Accumulated them while buying other radios, That had them included
The Racing Headphones I posted above did work real well.
JCar24
RaleighGuy passed along frequency sheets for Cup and Xfinity from Roval24.
Attached are the changes to my master list for Cup.
I'll get to the Xfinity list in a day or two.
Thanks again to RaleighGuy.
  • Roval24Cup.zip
ShortTop
Thanks for the updated list!
JCar24
Heads up about MRN radio frequencies.
For the past two weeks, the Racing Electronics at the track page has this notice on it.
MRN Radio Broadcast Frequencies: Primary = 454.2000, Channel 68 | Backup = 454.0000, Channel 69
Find us at the track
evilbrad
You beat me to it lol. And per someone at Phoenix this is confirmed. Is it correct that mrn or prn reporters are still on 450/455 then it's rebroadcast back to 454.00 or 454.200? At truck and xfinity I mainly did a quick 450-451 and 455-456 and noted tones or constant carrier never actually id",ed use specifics in 2024.
evilbrad
If anyone wants a video/audio clip of the Re3000 ota dm me.
