2025 MOSWIN Sites/Talkgroups
llzel
St Louis, MO
can someone who monitors MSHP Troop C, specifically in Franklin County but also STLCO, can you advise which dispatch channel they use. there are 6. I have a unication so I'm looking to program TIA
llzel
St Louis, MO
Thanks for the info, I saw that in the data base but didn't want to use up space. I'll program 5,6 and 7
MissouriSirens
St. Louis, MO
If you are out of reach on the Weldon Spring site, the Imperial site will work as well. I was out of luck with the Weldon Spring site, tried the Imperial site out of curiosity and it worked.
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
Greetings - just visiting for a short time and figured I would send my observations.
this is my current view on MOSWIN from Warrensburg.
The 3.98 site has been full-scale on multiple visits to this area over the last year or so - I don't think it's "Trailer 2" anymore - this seems to be a permanent site. Based on traffic, this seems to be the most active site and is by far the highest signal strength site near me - Surprised this has not migrated to the Zone 5 side of the system, but (??)
I hear 4 700 MOSWIN sites from my very limited QTH in Warrensburg:
5.25 Odessa
5.22 Windsor 700
5.19 Warrensburg (my name, not on RR)
3.98 Johnson Co (my name, in RR as "Trailer 2")
Notes:
the picture above shows two sites, 1.51 and 1.75 that are isolated - unknown reason, but those 2 sites are not in the RR dB - I do not know but it's possible those sites have been moved to Z5?
the 5.22 Windsor site is reporting a neighbor site 5.7 with CC of 169.6625 - I cannot hear this site from my current QTH and 5.7 is not in the RR dB.
I will update / add to this post as needed.
Merry Christmas!
batdude
Moderator
batdude
Moderator
FYI, the 3.98 site seems to carry primarily Pettis County TG traffic. The signal is VERY strong in Warrensburg, however.
if the location on the WRZF788 license is correct, that is a fairly long stretch for Pettis Co on 700 MHz... 20+ miles to Sedalia.
of note, I have NOT seen ANY Johnson County agencies on the 3.98 site.
batdude
Moderator
The Odessa 700 site (5.25) has the following users:
Higginsville PD
Concordia PD
Ray County Sheriff
those are the only users noted on this site with DSD+ after running on the system for 12+ hours
batdude
Moderator
Site 5.5 (Lawson) is reporting that sites 1.68. 1.29, 1.83, 1.88 and 1.28 are isolated. Could be temporary or (??).
note that the CC 169.6625 is also reported as a neighbor (Site 5.7) on the Lawson 700 site.
talkpair
Clinton County, MO
1766583315282-png.194418
Site 1.51 was most likely Sedalia before it was moved to Zone 5
Site 1.75 was most likely Windsor before it was moved to Zone 5 (The CC channels match)
169.6625 is most likely Cole Camp if Windsor reports it as a neighbor.
There are still a few sites in Troop A and Troop H that still appear in the database in Zone 1:
Holden, Avalon, Carrollton, Cole Camp, and Trenton.
You never mentioned the frequency of the control channel you are calling Warrensburg. Could you be on the Holden site? Seems odd it would be in Zone 3 though.
