396t
OnePcDoc
Yorktown
need help looking for usb cable i guess tried to register unit on uniden web site says i have to update scanner before i can register it
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Hmm...you should be able to register before you do any updating - that's a UPMan question...
However, the USB cable is available from Scanner Master, it's called the USB-1. The following 2 links (anything in blue) give you some hints/kinks about making the connection between the scanner and PC (it's written for XP, but there should be enough detail there for Vista or Win7 to use as a guide), and the 2nd is to Uniden's TWiki site - at the bottom is the link for the Prolific drivers.
Connecting scanners via USB - The RadioReference Wiki
http://info.uniden.com/twiki/bin/view/UnidenMan4/USB-1Drivers
73 Mike
torontokris
Toronto Canada
He'll need to load the ESN loader before registering (if he's on the very first firmware) to that he has an ESN/checksum
The suggested cables are USB-1or any serial/USB adapter can be bought at radioshack or eBay (ensure it comes with drivers)
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Right you are. It's been so long since I did mine, I'd forgotten the exact steps. 73 Mike
OnePcDoc
Yorktown
is it me or is the manual for this scanner aweful it could be i've been a radio shack scanner guy for ever got a pro-95 pro-96 pro-97 i can't get to seem to get this scanner to work like i want
next is there a program out there like software for the radio shack scanners
rvictor
Milwaukee, WI
It would be a lot easier to answer your questions if we didn't have to decrypt them. Sentences, punctuation, etc. would be a big help. There is no requirement that you do so, of course, but you'll increase the amount of help you get if you make it easier for us to respond.
Dick
