Getting difficult to find a 4gb micro SD card, any suggestions?
DSC45 Member Premium Subscriber Joined Jul 24, 2009 Messages 798 Location Central Jersey Apr 6, 2017 #1 Getting difficult to find a 4gb micro SD card, any suggestions?
toastycookies Member Joined May 29, 2010 Messages 726 Location the far east Apr 6, 2017 #2 You can grab a samsung evo 32gig for $12. Is there a reason you want a 4gb model?
DSC45 Member Premium Subscriber Joined Jul 24, 2009 Messages 798 Location Central Jersey Apr 6, 2017 #3 toastycookies said: You can grab a samsung evo 32gig for $12. Is there a reason you want a 4gb model? Click to expand... Only to replace existing micro card with the correct card.
jonwienke More Info Coming Soon! Joined Jul 18, 2014 Messages 13,409 Location VA Apr 6, 2017 #4 https://www.amazon.com/dp/B01HU3Q6F2 If you have Replay active, a larger card spreads out the wear on the card so it lasts longer. There is nothing "incorrect" about using a larger card.
DSC45 Member Premium Subscriber Joined Jul 24, 2009 Messages 798 Location Central Jersey Apr 6, 2017 #5 jonwienke said: https://www.amazon.com/dp/B01HU3Q6F2 If you have Replay active, a larger card spreads out the wear on the card so it lasts longer. Click to expand... So, you can put a larger capacity card in without hurting the scanner?
toastycookies Member Joined May 29, 2010 Messages 726 Location the far east Apr 6, 2017 #6 DSC45 said: Only to replace existing micro card with the correct card. Click to expand... They are compatible.
DSC45 Member Premium Subscriber Joined Jul 24, 2009 Messages 798 Location Central Jersey Apr 6, 2017 #7 Thanks so much!
