Hi everyone!
Happy Friday!
There is an update to EZ Scan today.
Updates can be found on our website or through doing an update from your scanner.
Happy Scanning!
Here are the change notes:
WS1080/WS1088/WS1095/WS1098/TRX-1/TRX-2
TRX-1E/TRX-2E
Happy Friday!
Happy Scanning!
- Added export and import of trunked system sites. This is implemented as a right click menu in the site list. Please note: Sites imported from the library will not be exported. Only sites manually created or imported via the text import.
- Fixed an issue with using the option to center selected alpha tags would reset the delay time to 0.
- Fixed an issue where the search delay time setting was not being saved properly.
- Fixed a typo on the aircraft search section to read 108 - 118 MHz.
- Fixed issues with import and export of talkgroup and radio ID objects.
- Fixed a display issue on some delay time values on the Talkgroup and Radio ID listings.
TRX-1E/TRX-2E
- Fixed an issue where the WX button mode setting was not being saved properly.
- Fixed the CB search function for the France bandplan to show the correct range.
- Fixed an issue where the "Skip DMR TGID" option is missing on the e model firmware.
