Hi All,
Been playing with the Butel ARC Streamer software and my 996. The problem is I cannot get audio out of the record jack.
I've gone into the conventional and trunked systems I want to enable for record audio and set the system record option to all. No audio out of record jack.
Next I set each conventional channel and talkgroup to record enabled and set the corresponding systems to record selected. Still no audio out. The streamer software works fine using the speaker out.
I've tried adjusting the line in level on the Audigy 2 ZS to max and still no go (in case level out of record jack was low).
Can someone else test record out to line in on PC and see if you can duplicate my problem?
Thanks,
Thanks,
