Question about how priority ID scan should work with a trunked system. I have the trunked system set as Priority ID scan and talkgroups defined with priority on. I have the scanner set to Priority scan on. I do not get any priority hits on these takgroups. I have other conventional channels that have priority set and do get hits. I thought it might be because I had the trunk system set to ID search so I made a copy of the system and set the copy to ID scan and only put in the priority talkgroups. I have had hits on the talkgroups on the original id search system? I must be missing something? This is a motorola type ii smartzone system and I have tried with status bit on/off.
