First the problem. All audio, including analog audio is chopped. I get 6 out of 7 words. Because by trade, I am a network administrator I will put it in computer geek terms. It is like listening to audio with regular packet loss.
Here are a list of things I have tried:
* Tweaking the P25 setting for digital channels and all of the suggestions related to P25 found on the forum and in the Wiki.
* Checking my squelch - seems like a no-brainer but yes, I checked it.
* Assured that I had the most recent firmware, I do.
Things I noticed:
* Squelch seems to close on many channels at the same interval on both analog and digital even when the squelch has been turned down all the way to zero - it is just as if some clown was dead-keying on top of those speaking - on every channel. I used my old Pro-46 on an analog channel side by side on the same channel, the reception was stronger on the Pro-46 and it was lossless.
* Even when I set a 9 second hold time on a system, it will resume scanning after 2 or 3 seconds, no matter how many times I reset it. It retains the settings I entered so, reset may be a bit misleading.
I checked 996XTs on the shelf in 2 different stores - they did the same thing, same firmware version!
Has this issue come up for anyone before? Suggestions?
Things I noticed:
