A/C Adapters
Nine29
Detroit, MI
Will the Radio Shack A/C adapter (9V/300ma) that I have for my Pro-96 with Adapta-plug "C" work with a GRE PSR-500?
Caesar
Lexington, SC
if it is the same plug with the the same tip +/- and you have batteries in the radio you should not have any problem, but without batteries it will work, but it will be short on mA and might not function up to its full potential...
Nine29
Detroit, MI
I had assumed the 9V/300ma adapter would be powerful enough to run the PSR-500 since it works fine with my PRO-96. I was more curious about whether the Adapta-plug "C" would fit the jack on the GRE. Thanks for the replies...
Caesar
Lexington, SC
Pro 96 and PSR-500 are very different radios though.
ps- the wiki is a pretty amazing thing. :)
Recommended accessories (Not included with the radio) (PSR-500)
* RS #273-1863 9-Volt Vehicle DC-to-DC Adapter
* RS #273-1706 Adaptaplug C - Needed for the above adapter
Nine29
Detroit, MI
I checked the Wiki and it didn't say an A/C adapter was included with the PSR-500. Do I need to buy the 9V/500ma A/C adapter that SquierStrat referenced? I originally bought the Radio Shack 9V/300ma adapter for my PRO-96 and was hoping to use it for the PSR-500 I'm buying.
hoser147
Grand Lake St. Marys Ohio
Ceasar is correct, it will not scan as fast as it would with the 500ma power source......
Nine29
Detroit, MI
Is that also the case with the PRO-96? The local RS store sold me the 9V/300ma adapter for it several years ago and never said anything about scan speed and the size of the A/C adapter.
DonS
Franktown, CO
So apparently the PRO-96 operates at a lower power level. Interesting...
Not necessarily.
My PSR-500 runs just fine (while charging batteries) on an old Sony wall wart which is labeled "9VDC 300mA". Either the PSR-500 is happy with 300mA, the batteries really aren't being charged, or the wall wart can really supply more than 300mA (or some combination of these).
Nine29
Detroit, MI
Oh well, I'll give it a try with the RS adapter and see what happens.
...and Don, another thumbs-up on your Win96 software!
Nine29
Detroit, MI
I need two adapters...one for home and one for the office. I was hoping to save the extra expense of buying a second adapter for the PSR-500.
DonS
Franktown, CO
Ah - that explains it.
Well, if you're not going to be charging batteries in the scanner, then a 9V/300mA adapter should work fine. I used such a wall wart (that I had for my PRO-93 through PRO-97) on my PSR-500 for quite a while.
pratzert
Maybe you can order another walwart from GRE ???
Tim
