The moment Unication adds Phase 2 to the G5 (or maybe it'd be the G6?) then I'll set aside money to buy one. Everybody seems to love these things.
Good idea. Never like to buy things based upon a future promise. It might never happen or P2 sucks and the G6 phase 2 is the real deal
Yes the these Unication pagers are great its a amazing little radio even fits in the palm of my hand, rocksolid construction (good enough for explosive atmosphere and IP67)
I suspect these things are SDR architecture with some kind of ARM cpu for the control plane. I could see the G5 supporting DMR tier III if they chose to do so.
It have a punchy clean audio you can even hear the background in the room where the dispatcher works, key clicks etc.. very clear. It does not matter where this radio is it can be laying down in the car seat cushion, on the floor, in a metal shed,inside my pocket,etc..
The only thing I would like to see is some kind of (compressor/limiter) to push up the audio when someone is talking into a mike 5 feet away
The G4/G5 is high quality commercial subscriber radio and do not miss a call period since they are obviously used for critical applications such as Fire dispatch paging etc. I do recommend if you end up buying one is get the stand, using the USB charger connector is a pain and I could see it wearing out the connector if you do this day in day out. Great for programming not great for charging.
I like drop in charging like the work radio. (plus it can lock in place using the belt clip end)
Guys at work are impressed with it and all want one.
