AAA Ambulance
INDY72
Indianapolis, IN
Speaking of AMR.... Are they still simulcasting on the Hinds TRS? Also do you ever get a chance to go down into Simpson Co? If so can you nab the Slot, TG and CC for AMR down that way?
And on the Simpson Co note.... Anyone that can confirm current status of the LTR system there, is SCSO on it at all, or MSWIN full time only? CC, SLOT and TG of the only PD down there on its own DMR system? Most of the data in the DB for Simpson is from what I gathered myself back when I was still living in MS. So it is a tad old.
INDY72
Indianapolis, IN
SEMAAD aircraft make almost daily trips to Jackson.
Really? They have stepped up. Back in the days of only Rescue 7 in operation, it was rare for them to fly to UMC as usually they did hop to FGH, and then rolled by land to UMC unless it was really needed. Though they did go to GBC rather more frequently! Goes to show what happens when you have 3 primary birds and Rescue 7 as backup now.
dosboot
Laurel, MS.
They have the rescued 7 ship plus the Med-Trans Corp. ships that the contracted the service to. they were working with Baptist life flight for a while.
riccom
My wife and kids said i have to many radios!
Yankton, South Dakota
Amr is simulcasting on hctrs and in the clear on the dispatch side and when I can i will tune them up on dsd+ and grab a signal
motorola2935
Just so y'all know the bright yellow bird is the UMMC AirCare spare unit they use while their other aircraft are out for maintenance. The helicopter is owned by PHI Air Medical and is in their classic scheme. The only Air Evac Inc. flights are based on the Mississippi River up north and across the river in Louisiana actually rare they make flights to UMMC.
Image Link to backup UMMC H-135:
https://i.ytimg.com/vi/t4shFO9VXBo/maxresdefault.jpg
riccom
Thought phi air was air evac or did they buy out the Arizona air evac?
INDY72
Indianapolis, IN
Phil and ael are separate companies Phil was first and is biggest
Sent from my LG-K330 using Tapatalk
riccom
Milf sending a message to you found a new trs
INDY72
Indianapolis, IN
Probably mccomb or Lawrence or one of the other ones at sw edge of semaad aaa area.
dosboot
Laurel, MS.
I heard once in Laurel this morning. I'm still trying to find out if they dispatch EMSERV on the highband or MSWIN.
shfd7
Pike County, Mississippi
AAA still uses vhf in pike county. They also use state ambulance freq. to talk to southwest hospital.
I have heard AAA in Hattiesburg, which they dispatch out from.
dosboot
Laurel, MS.
I've heard them in Hattiesburg using the on convention Frequency they were using before, what's the state ambulance frequency?
INDY72
Indianapolis, IN
155.3400 SERN 155.2800 SHN 155.1600 SARN
dosboot
Laurel, MS.
I'll put that in and see if I hear anything, thanks.
dosboot
Laurel, MS.
I'm still trying to figure out what AAA uses in Laurel for EMSERV.
INDY72
Indianapolis, IN
State Er net. State hospital net
