Abell A-81
abellradio
Banned
Abell A-81 is a super valued radio with many signals. 2-Tone, 5-Tone, DTMF, PTT-ID, ADC1200(compatible with MDC1200), all these features enable users to manage a working team easily. What's more, IP67 dust and water proof class allows you to wash the A-81 even it can be immersed into 0.5m water lasts for 30 seconds.
Following are the features of this model:
Wide-band Coverage
UHF 400-470MHz, VHF136-174MHz, allows users the flexibility to select frequency for use in their respective work environment.。
128 Channels
Totally 128 channels allows group users to be assigned their special channels.
High/Low output power switchable
The feature allows user to switch to low output power in short distance communication to save battery.
High capacity battery
1600mAh Li-ion battery can stand by 14 hours long work time..
Annunciation
The feature enables radio to report the current channel number and output power when power on or switching channel, to report the battery capacity when you press the programmed function button, offering you notable convenience.
CTCSS/DCS
50 groups CTCSS and 104 groups DCS for a better anti-interference and comfortable communication.
Wide/Narrow band programmable
The feature allows user to utilize the frequency they preferred.
Priority Scan
Busy Channel Lockout
Battery Save
Low battery Alert
Loud and clear voice
Voice compander and FST high performance speaker ensure max1.5W Audio Output loud and clear voice
Dual mode Alarm
Press the emergency key to emit alarm siren to work team radios or the radio sounds alarm sirens itself。
IP66+ Water proof and dust proof
The feature allows you to wash the A-81 even it can be immersed into 0.5m water lasts for 30 seconds.
Shock proof
The strengthened aluminum chassis is much thicker than ordinary radios, it protects A-81 drops from 4m high to cement ground without damage and can stand-by a car pass on it..
3 Programmable button
The feature allows user to set A-81 according to their individual needs which is user friendly.
VOX
The feature allows user hands free operation..
2TONE/5TONE and DTMF encode
The features allow you to establish your own working groups an quiet stand-by when others are talking.
PTT ID Encode
The feature enables user to manage a working team easily.
