DSDPlus About dsd+
fgfgfg
Looks like its trying to decode data and showing errors. Don't see any voice calls in your pic. How are you attempting now? Are you using FMP24 with DSDPlus or still using sdr# and virtual cables?
Yeah, still sdr with vb, using 1R.bat
fgfgfg
Have you confirmed with another receiver there are active voice (or what you refer to as "speech") transmissions that DSDPlus isn't decoding? Your screenshot looks like weak data to me
Keep an eye out in the console window for this when there are active voice transmissions
You'll also want to keep an eye on your event log window. Active voice will be light green and past voice events will be a darker green
This will log encrypted voice events like shown below but won't decrypt conversations
No, I have only one receiver, but thanks for all this info
fgfgfg
First pic is what fmp24.exe shows and second is fmp24-vc.bat
dave3825
Suffolk County NY
There is no need to use all that extra garbage.
With just one dongle, one can use both DSDPlus and fmp24 and decode and also follow calls on a trunked system and conventional freqs.
View attachment 206202View attachment 206203
Clicking fmp24.exe will try to open using the use first available dongle switch. (-i0)
Launching fmp24-vc will try dongle number 2, which your system is saying is in use. Either driver issue or its in use in sdr#.
Do not use fmp24.exe or fmp24-vc. Use Fmp24-CC.bat. Make sure the dongle is not running in sdr crap or fmp24 wont be able to open it.
Once you get fmp24 open and looking something like this, type in the freq you want to scan and verify you can see it on the spectrum.
Then open 1r.bat
fgfgfg
Then open 1r.bat
Woah, how many steps, thanks, I'll try
gary123
For DSD to be happy you often have to start the individual .bats in order.
1 start your edited to the CC frequency FMP24-CC.bat
2 start the FMP24-VC the stock configuration should be fine
3 start the DSD R1.bat
This should get everything running correctly with 2 SDR dongles.
Once you get it going properly let us know and I will see if I have a few minutes to make you a single .bat that will do all of this in one step. In my configuration I am only using one SDR but it might be interesting to do some logging using 2.
lwvmobile
DSD-FME
Hi everyone, I'm using:
sdr# from here SDR# and Airspy Downloads - AIRSPY (Jan 1, 2025)
dsd+ from here DSDPlus – Digital Decoder (Dec 4, 2025)
and VBCable.
Don't mean to randomly jump in here in the middle of the night and hijack things, but just out of curiosity, is there some guide somewhere, or some youtube video, or group where they recommend this setup. I find that a lot of people use this setup, and more often than not, the setup is terrible. I often get SDR# IF recordings that are not conducive to replay and analysis, and from what I see from the end users own demonstrations of their setups, that the decodes are often trashed, or not very good.
cg
Connecticut
In the early days of DSDPlus, before FMP was added, I believe you needed to use that setup. Then FMP was a couple years later. However, the vast majority of those same kind of posts that you mentioned seem to be much newer users.
It also may be that the support was for the RTL-SDR and Airspy but not the newer brands/types of SDRs until fairly recently.
chris
gary123
I have used numerous SDRs with DSDPlus. This includes Airspy R2, SDR V2,3,4 as well as a couple of Ail Express $15 dongles. All of them worked with the support files in DSDPlus. The R2 uses the R1.bat and the SDR uses the FMP24 .bat. The Ali express ones I do not remember which configuration or .bat I used.
My recommendation is to use the SDR v3 or v4 dongle and use the .bat files posted here and in other threads.
fgfgfg
I've got only one, unfortunately
