Ac Adapter for GRE-600
tbharper
Lafayette TN
I am needing a AC Adapter for a GRE PSR-600 scanner, does anyone know where I can get one?
gewecke
Banned
Illinois
Radio shack ( If you can find one in your area ) or walmart, almost any hardware or store with electronics. It needs to be a 12vdc ,700- 1000 ma and the tip needs to be positive polarity (+) :wink: 73, n9zas
Blackswan73
Central Indiana
You will not likely find it at Walmart. The tip is similar to Sony laptops. Whistler does have it for around $18 plus shipping. It is the same as the 1065
gewecke
Banned
Illinois
I did at my Walmart, so I bought a spare to have in another room so I wouldn't have to unplug the Oem wall wart. :wink: 73, n9zas
iMONITOR
Silent Key
S.E. Michigan
. Yeah, I thought about them, but wasn't certain if polarity would be the same, thanks. :wink: 73, n9zas
I'd be pretty certain Whistler would confirm that for you. They would know.
It's easy enough to check, easy enough to reverse if necessary.
gewecke
Banned
Illinois
I'm not the one who needs the information, the Op is. :wink: 73, n9zas
dkf435
Sweet Home/Foster OR
The radio uses standard EIAJ-05 power plugs found on many Panasonic , Sony and Kenwood adapters for the 13.5v to 18.0v range , often adapters at Goodwill or other second hand stores.
Radio Shack adaptaplug "T" or Philmore TC265 fits. 6.5mm OD x 4.4mm ID x 1.4mm pin
David
