Does anyone know what these Advanced DSP (Digital Signal Processing) settings actually do? They are located under the Advanced Tab in the EZScan software. For instance the DSP Level Adapt: is set in my scanner for 64. I'm assuming that this is a digital setting of some kind since it has 256 values.
The other two settings in this box are ADC and DAC which I'm guessing is Analog to Digital Conversion and Digital to Analog Conversion. They're both set to 0db. Again, I'm guessing that the setting is for the amount of gain/loss cranked in during conversion.
I'd also like to know when these settings should be changed? What effect any changes would have and under what conditions is it necessary to change them?
GRE obviously intends for the user to change these settings but they don't give any info on when or why they need to be changed. I've done a little searching on the Internet but I can't find anything specific to the PSR-800 or even GRE scanners. If you've got any info, I sure would like for you to share.
