ScanWV
Any ideas on a good aftermarket all band antenna? Have a new pro 106 and have a 800 mhz antenna but it lacks in lower bands. Ideas for portable, mobile and base antennas are appreciated. Looking to upgrade in all aspects. thanks
Quoting from Strong Signals testing performed in 1999 that can be found here:http://www.scannermaster.com/ProductDetails.asp?ProductCode=28-541173&CartID=2
Ive ben highly considering that one
http://www.strongsignals.net/access...pe=display&rtype=rev&class=ant&num=003#080799
"Comparing the scores for the 4 longest, non-telescoping models puts the W881 in the lead with the RH-77CA and RD-78 back one "point", and the RD-98 back 6 points. So, for all intents and purposes, the W881, RH-77CA and RD-78 perform identically. Considering the latest pricing, the RH-77CA rings in at $25, the W881 at $35, the RD-78 at $23, and the RD-98 at $25. Comparing price versus performance makes the decision between these pretty easy"
Dave
The W881 and the RH77 are equally good in performance according to this test. So buy whatever is cheaper, which at the time of this test was the RH77. Just check prices today, if price is an issue, and decide for yourself. The W881 is a good antenna, but somewhat expensive.alittle confused, so would that be a good antenna? or no?
Dave
What radio was it tested on by chance do you know?
id be using it for the 106
As is explained in the test report:What radio was it tested on by chance do you know?
