Anne Arundel County Radio System Upgrade
maus92
The OP
The New Crownsville site has structure delivered, and what appears to be a new fiber optic leg installed along Hawkins Road - perhaps they made a deal with the state to share fiber since they are co-locating the new tower alongside the existing MIEMSS / First site.
The Davidsonville site has finally got some tower construction happening:
maus92
The OP
And the Lothian site has completed erecting the tower structure, and has even mounted one RF antenna. You can see the transmission line race on the ground waiting to be installed. The shelter is in place, along with a backup genny mounted on top of the fuel tank - I don't think I've noticed that before, but it's a good idea if vibration in minimal.
maus92
The OP
Tower structure complete at Davidsonville; that leaves only the monopole at Brooklyn Park and New Crownsville yet to be completed.
maus92
The OP
And the Brooklyn Park site monopole has been erected- almost got all the towers up before going home for Christmas.
maus92
The OP
Anne Arundel units have been running a disturbing number of positive PUIs this morning. Merry Christmas.
maus92
The OP
PUI responses continue to wreak havoc with transport units and hospitals today. Annapolis area is being covered by transfers; most area hospitals are on condition red and yellow; both county hospitals are on reroute:
\chats-r3 - 122921-1555.PNG:
maus92
The OP
The county has posted a sign where the Herald Harbor VFD is moving to - the site of the old Wawa on Generals Hwy at Sunrise Beach Road. New name too: Crownsville Fire Station. Completion date Fall 2024. The new Jacobsville station is nearing completion, and the relocated Woodland Beach station will be located at Rt 2 and Rt 214 in Edgewater
ThePhotoGuy
Maryland
January 28, 2022
Federal Communications Commission
445 12th Street SW
Washington, DC 20554
THIRD ANNIVERSARY SLOW GROWTH/EXTENDED IMPLEMENTATION STATUS
UPDATE FOR WRCY532
To Whom It May Concern:
On February 26, 2019, the Commission issued callsign WRCY532 to Anne Arundel County, Maryland (the County) with slow growth/extended implementation status, to provide eight new 800 MHz frequencies to the County for use in a future Next Generation APCO-25 Public Safety
Trunked Radio system. Pursuant to 47CFR90.629(c), the County is providing this Third Anniversary Slow Growth/Extended Implementation Status Update for WRCY532:
• The following processes in the County’s project plan are complete:
o Site acquisition
o Detailed system design review
o Frequency planning, regulatory work (e.g., FAA/FCC/NEPA/SHPO, etc.)
o Factory staging and acceptance testing
o Communications site and tower civil design
o Public safety subscriber radio deployment
o Augmentation of existing towers to meet current code requirements, except for the ca. 1937 Greenbury Point tower that will be utilized as WRCJ217 Location 3
o Electrical system augmentation at existing sites
o Shipment of system LMR and microwave equipment from the factory to Maryland
o Site construction at seven (of ten) existing sites
o Site construction at four (of four) colocation sites
o Site construction at two (of eight) green field sites
o Site construction at two (of four) dispatch centers
• The following processes in the County’s project plan are currently active:
o Installation of new base station repeaters and other network equipment in equipment shelters
o Fiber backhaul outside plant construction
o Microwave backhaul antenna and equipment installation
o Installation of antennas and new electrical systems at dispatch centers
o Implementation of tower augmentations at WRCJ217 Location 3 Greenbury Point tower
o Site construction at three remaining existing sites
o Site construction at six remaining green field sites
maus92
The OP
Truck 39 has been testing Repeat 3 on Mike in a structure somewhere in the Annapolis area this morning. They were also testing RINS 1 as a direct channel - not sure if RINS 1 always uses a repeater - I don't know why they would be using RINS in a structure if it relies on infrastructure. Perhaps testing a BDA? Just a note when you hear a tone burst in front of a transmission, it indicates that a VRS channel is being used.
empire550
Maryland
RINS does not use repeaters here.
maus92
The OP
The county's RINS license WRCC324 confirms this, but also indicates a Temporary Fixed mode. Perhaps the county's MCP (or SOW if there is one) has a capability to repeat these channels? /speculation.
maus92
The OP
AACo is experiencing a radio failure this morning: all tgs out except for Bravo and Charlie on the TRS.
maus92
The OP
Hotel has been added to the working tg list. Not sure if the outage is related to being in the AECC in Glen Burnie (if they are still there.)
maus92
The OP
Seems like a console issue, however I looked at my logging software this morning, and it had dropped the AACo system at 10:59 last night. The software typically runs 24/7 for weeks at a time without failure, so I'm not sure if it was coincidental or not. Seems related, particularly since it was also logging FIRST which was not interrupted. The post at 12:52am was made after a long tone sequence announcing the problem.
