RID is not slated for V1.
Can I use the same UASD files for both, for example?
2. Encrypted transmission skip or rescan. Some trunk talkgroups and some conventional channels are encrypted only some of the time. To hear the unencrypted comms, we must leave the talkgroup or channel in the scan list. And that means we will hear lots of annoying noise whenever the comms are encrypted, and forces us to repeatedly press the scan button to get the scanner going again when it stops on scrambled speech.
This encrypted skip function, when activated, would cause the scanner to skip encrypted communications or continue scanning after detecting an encrypted transmission. This is probably possible only on a transmission that is digital and encrypted.
The incrteased memory is much needed. I work for a TV station in Central Florida, and we send news crews all over the state. This amount of memory will allow me to program all the radio services in the state for instant access by our crews covering breaking stories.
Hey, this significant memory expansion is great news, thanks for this very helpful discussion.
Here's my wish list for Uniden:
1. Allow 300 or more quick keys, so we can assign quick keys to all radio systems we program, allowing users to more simply and quickly activate and deactivate systems.
Depends on the signal type (conventional vs. trunked, trunked system type).The GRE's and Radio Shacks that do NOT do this.
UPMan stated that
You can assign each system a number tag between 0-999. Duplicates are allowed
Not sure if thats the same as quick keys, but that should help you.
