Another Blue Tooth Question
nitetrain5
Family Guy
CT
OK I read several posts regarding the use of bluetooth to listen to the scanner. I purchased a Jabra A210 adapter and tried a Jabra BT530 and Moto H375 for earpieces. I can't get any audio through either ear piece. Going by the flashing lights on the pieces, it appears that they are paired up..... but no sound. At the risk of beating the subject to death, any help would be greatly appreciated!
Thanks!!
Gator596
Niagara Region - Canada
Three quick things to check that all stumped me when I set mine up;
a) earpiece volume set on high
b) scanner is locked on to something you can hear (set it to NOAA or some other continuous voice broadcast)
c) pairing is not always instantaneous. I found that mine took up to 20 seconds on the first attempt. 20 seconds is a long time in a world where everything else happens fast.
ilgrant
Chicago, IL
Did you try different swich posions that adjusts for the different types of bluetooth devices?
N
N_Jay
Guest
Are you sure you are converting from the cellular (TX - RX Audio) style plug to the earphone (R - L Audio) style plug?
nitetrain5
Family Guy
CT
I'm not really sure about the style plug. I'm using an adapter to go from the 2.5mm to 3.5mm and the jabra adapter as well as the 3.5mm adapter have two black rings which I assumed were the same..... I wasn't aware of tx/rx audio and r-l audio plugs being different other than size. Mmmmmm.. maybe I should look into that further. Thanks
nitetrain5
Family Guy
CT
I did try each switch several times. I'm still tinkering around trying to get it to work. Thanks
nitetrain5
Family Guy
CT
I tried the ear piece at all different levels, had the scanner tuned to constant traffic, and I waited ,and waited,and waited. The led's did flash after a while which seemed to indicate they were paired.....but I'm not positive of that. Thanks for your help
ilgrant
Chicago, IL
I'm using the Bluetooth adapter (same model as yours) with the 2.5 to 3.5 mm adapter from RS. It should work unless there is something wrong with the Bluetooth adapter.
One thing that I remember and just tried it here...make sure that the 2.5 is plugged into the 3.5 adapter all the way. On the Radio Shack one it feels like it's plugged in. A little more pressure and then there is a loud 'click'.
My switch on the adapter is set to 1 and works fine on the two Uniden receivers I have. Make sure the adapter is the stereo type with three connections. There are some that may have 4 and may not work.
From a troubleshooting standpoint I would see if the adapter works on a receiver that doesn't require the adapter.
nitetrain5
Family Guy
CT
Wirelessly posted (BlackBerry9530/5.0.0.328 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
Hi much thanks to everyone for your help! I finally figured out what was wrong. The 3.5mm to 2.5mm adapter I was using was accidentally stero on one end and female side was mono thus not picking up the signal. Works like a charm!
