Sentinel: Another Sentinel Question
Bubba1661
WV DB Admin
Charleston W.V.
Ok My question is can I build a file on Sentinel on my computer and be able to send it to another computer with Sentinel on it. Do I zip it to a Hpe file or what? Any help would be appreciated.
rk911
Rich
Wheaton, IL
if the other pc is yours or even someone elses just put the file on a thumb drive. if both pc's are on the same network you can copy files from one pc to the other using Windows Explorer or something like GoodSync.
jtwalker
BEE00.1E8-1.22 (or) BEE00.689-1.13
Use export and import functionality. The zip process is to post here on RR because the forum doesn’t trust every file type and I guess .hpe is not one of the trusted ones.
gmclam
Fair Oaks, CA
There's several files involved so it depends on what you exactly want to share. I wanted to share an entire profile, which contains several Favorites Lists, and had to hunt down where that's stored. I found one of mine in the following folder: C:\Documents and Settings\George\My Documents\Uniden\BCDx36HP\Profile\NW_2023-07-01
It will contain your user name, rather than mine. Yeah the model is BCD... even though this is for the SDS-100.
belvdr
Why not export it to an hpe file and make things easy? No need to locate anything in that directory.
gmclam
Fair Oaks, CA
I believe each hpe file is one Favorites List. As I mentioned, I wanted to share the entire profile, hence the search for it. And neither of these include the Custom Display settings.
belvdr
For certain, one FL per HPE. I guess compressing the entire folder into a zip file would work. Never tried that before. You can always export the display settings too.
gmclam
Fair Oaks, CA
Yup. One file for display settings, one file for each FL and that still doesn't get it all. It depends on how much and what you want to share. I've used the WINXXX software virtually since it came out and got spoiled. While most users know about hpe files, few understand where stuff is actually stored (in the event you want to share the entire profile).
