desertscan
- Joined
- Jan 15, 2012
- Messages
- 48
I just got a TRX-1 about a week and a half ago and cant figure out how to program it the way I would like.
Is there a way to program each scanlist as a bank like in the older scanners? (RS Pro 106).
I would like to have one scanlist as a roaming style and have one scanlist separate for each site (area) but cant figure out how to do it.
Example: when in San Diego I would like to have one scanlist setup for one on the north site then one for the south site and one for the east site and being able to just switch from site to site by just switching from one scanlist to another so I can just listen to what I want to for each area.
I got the RS PRO 106 and it works great for this and would like to do the same with the TRX-1 if I can.
I would like to do the same scanlist setup for Imperial County, San Bernardino County, LA, and AZ when I travel thru Yuma to Phoenix.
Can this setup be done on the Unidens? Ill have to go buy one if it does.
When I try to do this the talkgroups just switch from one scanlist to another when programming even when having a scanset for each scanlist and when all scanlists are checked it reverts back to the best site available regardless of which scanlist is being scanned and when all scanlists are not checked it just says nothing to scan.
Thank you
Thank you
