Antenna help
feerods310
Currently using a Uniden Bearcat BCD396XT - I follow LAPD and LASD.
I want to upgrade my rubber duck antenna - does anyone have any suggestions for an upgrade?
Thanks!
ofd8001
Louisville, KY
You can take a look at the links below to see if anything is of interest.
If at all possible, try to get the SMA type antenna so as to avoid a BNC to SMA connector. Using adapters can somewhat reduce effectiveness.
In a perfect world, you could find an antenna tuned for the 400 band, but I've not seen any of those - most are geared toward 800. Still they function satisfactorily on the other bands.
http://www.theantennafarm.com/catal...-antennas-717/scanner-receiver-antennas-1117/
Portable Wide-Band Antennas for Police Scanner Radios | ScannerMaster.com
Portable Single-Band Antennas for Police Scanner Radios | ScannerMaster.com
cmdrwill
So Cali
A 1/4 wave antenna is best for the 470 band, about 6 inches. Avoid adapters as they change the antenna 'tuning' length.
