Antenna Masts
N9JIG
Sheriff
Moderator
Far NW Valley
It has been years since I bought an antenna mast. Living in HOA's or apartments for the last 40 years doesn't allow me such luxuries like external antennas much. Recently however I have installed one using a satellite dish mount off the side of my home. This has a 1 11/16 inch inside diameter pole receptacle. Most scanner antennas, like the ST-2 and Omni-X that I have used are built for a common TV antenna mast of 1 1/4 inches outside diameter.
I went into town the other day looking for a standard TV antenna mast, Ace, HomeDepot, Lowes and BestBuy all did not have them, nor do they have them on their websites. The sales guys looked at me like I was from Mars when I asked about it.
My plan was to use a short chunk of the 1 5/8 inch plastic pipe that I have been using as a stop-gap as a bushing, the 1 1/14 inch TV mast would fit nicely inside and then I could drill thru both for the two stainless steel bolts to secure this to the mount's pipe. Since no one had TV masts anymore I bought a piece of grey plastic pipe, again as a stop gap. It works but it is too flexible for my liking.
I investigated using plumbing pipe but that was too heavy at 5 feet, much less 10. It did fit inside that plastic pipe bushing I cut though. They had some other metal pipes but nothing that was the right diameter that was weather resistant.
So I went to Amazon, they have exactly one item for the mast, at $25 plus another $24 each for shipping. I wanted two, but $100 is too much for a couple pieces of galvanized pipe.
Eventually I remembered the good service I got from Channel Master when I ordered a couple 300 to 75-ohm baluns for my ST-2. I checked their website and was able to quickly find the masts I wanted at $19 each, with $17 shipping all together. I could have driven to their outlet in Chandler but that would be a 2-hour drive each way. I can wait a few days and pay the $17, it would cost me that much in gas anyway. For $55 I will have them in a few days, it will be a week or so before there is a sub-100-degree day anyway so I can live with the plastic as long as there aren't any windstorms before then.
If you need some classic TV antenna parts and accessories check out the Channel Master website, remember a lot of that stuff can be used for scanners.
prcguy
This might be useful even if you don’t build a push-up mast as the fence top rail is an excellent mast by itself.
trp2525
...Eventually I remembered the good service I got from Channel Master when I ordered a couple 300 to 75-ohm baluns for my ST-2. I checked their website and was able to quickly find the masts I wanted at $19 each, with $17 shipping all together...
A go-to place for me to purchase TV antenna and scanner antenna mounts/mounting hardware, splitters, masts, coax, etc. has been SolidSignal.com. I have personally purchased from them in the past and have found their pricing to be very good and they have excellent customer service/support after the sale.
Regarding TV/scanner antenna masts specifically, Solid Signal currently has the "Winegard 5ft Swedged Mast" for $17.99. Channel Master and Winegard have both been around for MANY years and I don't think you can go wrong purchasing either company's products. IMHO
devicelab
Radio N.E.R.D
WA (USA)
Wrong department. You can get EMT conduit (from Electrical) for $12 per 10ft in various OD sizes. For vertical antenna masts, I haven't tried one of the simple couplers, as there just isn't enough meat there to grab on to from each side.
I ended up using this from Amazon to create a 19ft mast. It worked quite well. I purchased two for the price of one -- at today's pricing.
Here's a different supplier:
VE2XWA
Montreal, Quebec
Yes - Chain-link fencing top rail sections make excellent antenna masts. They are typically galvanized,10'6" long, with one end swaged to fit into another section. Available at most big-box home stores.
I've been using a 15' top rail fence as a post for many years
nickwilson159
Hudson Valley
Not bad. I looked at our local hardware stores and they only sell 10 foot lengths but should be easy to stack together. Hmm...
Some local fencing suppliers carry 21' top rails, which work pretty well. I grabbed a 1-5/8" diameter one a few weeks ago for under $50.
BoCoMonitor
Erie, Co
If you want pro grade, these guys. I have installed many of their mounts for customers.
FlyingGorilla
Galvanized pipe with threaded ends will work. It's thick-walled, with 1/4-inch walls, so subtract 1/2-inch from the outside diameter you wish to use when buying pipe. Comes in 10-foot segments. Couplers are readily available and stand-offs will accept up to 2-inch outside diameter pipe.
devicelab
Radio N.E.R.D
WA (USA)
That stuff is WAY too heavy.
