Aor 8600 reset to factory default
theoldcop
Wilmington, NC
O.K. Raymond, looks like we have a little investigating to do!
Before we start, please believe me when I say I am, by no means, and expert in AR86ctrl, but I will do my best to help.
First, from looking at your screen grab, it looks like you have Scan list "A" chosen in the list window, but you are in the "Search" mode. It might be that you have to get out of the search mode and into the scan mode.
Here is what I recommend you try:
1st - In the "List" window, chose a SEARCH list. If you have none programmed, right click on a line and set up the search parameters. When done, right click again and chose "Search This Bank". Doing this will put AR86ctrl in a known condition.
2nd - Once the search has started, click on "Stop/Mem". This will take you out of the search mode and put you into the scan mode. Now, chose a "Scan Bank" from the drop-down menu in the "List" window. You should now be able to right-click on a line and "Edit a Memory Channel".
I'm quite sure their is a faster way to do this, but, as I said, I am new to AR86ctrl and this is how I use the software.
Tip, remember to always click on the "Refresh" button next to the "List" window as AR86ctrl will read and send (sort of a "sync" process) to and from the radio.
GOOD LUCK!!
John
on3rvl
gijzegem Belgium
Aor 8600 memory mode problem
I can't enter the memory mode as you proposed , perhaps other way ??
Whenever you find something plse let me know -))
kind regards
Raymond
theoldcop
Wilmington, NC
Sorry it didn't work out for you Raymond. I am at a loss at this time. Are you sure your radio is communicating with your PC? Do any other software demo's work? If your radio is talking to your PC, the only other thing I can suggest is to contact the AR86ctrl's author.
Best of luck.
John
on3rvl
gijzegem Belgium
Awnser Aor -)))
This the awnser Aor -)))
Dear Mr. Raymond,
I am sorry to hear that “memory clear” has not solved your problem.
It is obvious that your receiver is broken and needs servicing at the factory in Japan. But as expressed before, I doubt it would make sense financially because the total cost (servicing man-power charge, price of components to swap, international shipping both ways, probable import/export taxes, etc...) would be very high compared to the actual value of the receiver
Kind regards and thks for the efforts
Raymond
on3rvl
gijzegem Belgium
Scanning 8600
Hello ,
Is it possible to scan the aor8600 not only for 1 bank , but for all banks?
a= air
b= mil
c= nautical ..........
Raymond
theoldcop
Wilmington, NC
Sure. You can set up the Scan Bank Link to include any variation of banks you want. See section 7-7 in the manual.
John
