APX7000 Scan Reprogram Issue
Nbraves
I recently purchased an APX7000XE M3 and had it programmed for my local trucking system and conventional frequencies. The guy I had it programmed by went through channels to add to the scan list with me. I had changed my mind on a couple, talkgroups and conventional frequencies and planned on editing the scan list via holding the scan button (programmed purple button).
After I hold the scan button, the correct screen gets prompted on the back, but will not let me remove or add any channels to the list. I do have the ability to rewrite a new scan list on my CPS however, I don’t want to do that. Every time I change my mind I am not sure if I looked over a sitting in the CPS, but any solutions??
Nbraves
Is operator select enabled in the scan list?
Negative, thought that had to do with the priority members, and given I have to run multi-sys scan to cover what I want to listen to I lose that feature. Didn't even think about looking there.
Tech21
Nope, operator select is what allows the scan list to be edited by the end user of the radio.
For Multi-System Scan, set the non-priority members to operator select.
