ARC250 basix/BC796D programming
K3JTP
BALTIMORE, MD
I have downloaded Balt. County, MD fire, an APCO P25 Phase 1 System from RR to the ARC250basic software and thought I properly exported to the scanner. However, scanner does not stop scanning during dispatch, which I am now hearing on my R7100. Does the Butel software support P25? The Trunk Configuration menu in the software lists a number of Motorola systems, but not Motorola P25, so how am I supposed to configure the bank? I downloaded the rebanding firmware from the Uniden website. Hope someone can help.
K3JTP
BALTIMORE, MD
Thank you, I'm assuming you refer to Mot Type 2 800 Mhz. What would be the remaining typical settings for the channel config., especially the typical delay and Plan, since this system has 2 primary control and 6 alternate control channels.
