ARC996T beta
STiMULi
Tucson, Arizona
Butelsoftware said:
>I don't understand the SUB/LOG in the Log window.
SUB indicates a (new) detected subtone.
The Sub line should be an option. I do not want to see it. I just want to see what tones hit on what frequencies
>Are you planning to allow the Log/VC window to expand?
No, fixed for 800x600 screens
This is an aggravation as most people have larger than 800x600 as well as all fields can not be viewed. I can not expand the active log window
>Are you planning on allowing Record option to work only on record annotated channels?
No, scanner does not report this flag
But the software knows this. Can't you check it against a file?
Makes the Record option a waste of money for me
>Are you planning on adding the LAT/LON feature to the log window?
Not sure what you mean.
Adding the coordinates reported by the GPS through the scanner to the log file/window
>Are you planning on allowing the sorting the active log?
Is in the suggestions list.
>Adding new system still includes 10 groups. I must still delete all unused groups.
Correct this default, use edit groups to change the number of groups.
I cannot find that option. What is it called?
>In VC when rightmouse key is depressed to emulate F hold and VC-F is pressed to end F hold, the actual F (physical) knob will not work until the scanner is reset.
I have to check this.
>Cannot select multiple lines in group for channels for deletion or clearing.
We do not support multi line selections
When you right click over that area this is an option to choose from.
"Clear Selected LINES" - "Delete Selected LINES"
>When creating a conventional system not all agencies are checked at default. When using select all and deselect all the agencies not originally automatically selected are not affected. Even after it is selected manually, pressing the select all will deselect the manually selected agency.
Which system is this?
Many. I Used Arizona/Pima county and Why FD is one at issue
>Comments section still truncated. Comments section still removes spaces from imported info.
Is an option, click on Options tab in import screen.
Again, what is the name of this option as I cannot find it?
Gommert
www.butelsoftware.com
I'll check the options for the items I missed. Ok I looked, what options change the truncation of the comments field and what option prohibits the remaval of spaces?
I have responded to you responses in bold above.
Thanks for your help,
Butelsoftware
Dayton Hamvention
It is, check Log Settings tab.
There is a scrollbar and you can change width of columns.
No, Uniden should add this.
For now there are no plans to do this.
Right mouse click, Groups _ Edit groups.
Correct, hold down mousebutton to select an area. We do not support the shift/ctrl/ multi select/
In the radioref import click the options TAB.
Gommert
blueline_308
Eastern, NC
Is the analog audio only bug fixed yet, and how about the sites getting rearranged bug?
BL
blueline_308
Eastern, NC
The problem with sites just appearing where they want to...
Here is a screen capture showing how the 'CUMBERLAND TRS' site just magically appeared in place of the 'CAMP LEJUNE TRS' site. I wasn't even editing either of those systems. This is not the latest version from yesterday. I reverted back to the .904 beta basic version due to the 'analog audio' problem in the new release. Is anyone else having a problem like this?
blueline_308
Eastern, NC
YEA BUT .... It did it when I was using .910 last night until I found the 'ANALOG' problem, and re-installed older version, so I don't think it's completely fixed yet...
STiMULi
Tucson, Arizona
Will individual subtones log with the checkbox unchecked?
I want each hit logged with the individual subtone without the SUB Line is this possible?
Leaving the SUB line on already uses the precious real estate that will not be freed up to view fast moving activity.
As far as the log window goes I can not adjust the fields to the point to see the all of the pertinent information. As a programmer I do not understand your unwillingness to allow that window size to be user defined.
I have started a thread about the lack of the REC output during a scanner STAT call. No one has added to it. I will do some research and find all the reasons that others and myself have given for a firmware upgrade to the scanner and start a new thread. Hopefully this will give attention to these issues. It is hard for me to believe that the designers would have not thought about this in there extensive list of calls.
Needless to say I am disappointed with both the Record and Log feature as they are implemented in the software at this time.
Pertaining to the Systems and Groups... Either I am not verbalizing my request correctly or I am misunderstanding your response.
I click on Add System button.
It adds a system
Within that system is 10 groups, all empty.
How do I prevent those groups from being automatically created?
blueline_308
Eastern, NC
Stimuli, The way I do it is, Once the ten new groups are added, right click on the system and choose from the menu, 'edit groups'. From the window that opens, you can check or uncheck unwanted groups, set quick key, rename, etc. It's more convinient than having to rename or delete from the browser. Hope this helps. I haven't found a setting to control the number of groups created by default.
BL
WX5JCH
Elk City, Oklahoma
I've noticed that when I download systems from the scanner it does not display all the system quuick keys, just a few of them. When I go to the qk editor they are there ok but not all displayed in the browser.
Grommett, thanks for all your hard work on this bit of software, it is appreciated!!!!
Jim
Butelsoftware
Dayton Hamvention
Yes, if they are programmed in a channel they are logged.
The SUB line shows detected subtones (ctcss search mode) and there is no hitcount for detected tones.
A default conv. system in ARC996 always has 10 groups. You can use 'Edit groups' to toggle groups on/off.
Gommert
Woodie
Problem?
Seems that the software makes write errors. I had a small fleet net group set up rad it from the scanner, edited a few fields with arc and wrote it to the scanner. Data was lost and other errors crept in.
Could this be comm port speed?
Cheers
compubandit
SE Kansas
If I have VC up and running and record is on also, the program will lock up and shut down. I will turn it on and leave for work. I stop by to check on any new talkgroups and what is said on them and ARC is no longer running. No power outage or anything. Anyone had this happen?
STiMULi
Tucson, Arizona
I'll have to try again I stopped recording when I found that the log and record could not be doing 2 different things.
(Recording only certain channels and logging all)
mancow
N.E. Kansas
I hope I'm not bringing up an old issue, if so let me know but maybe someone can help me out with this.
I had ARC396 open along with ARC996. I was cutting and pasting stuff from the 396 to the 996. It all seemed to work fine. I programmed the 996 and when I read it back out the data was corrupted. Things were randomly strewn across different data fields all over the program.
Now I have to clear the 996 and start completly over.
What's up with that?
Woodie
Yea - This is the same thing that is happening to me :(
The problem is simple to re create.
1) Read a large group of channels from the scanner.
2) Delete the large group of channels from the scanner.
3) Write back the large group of channels.
4) Scroll through them on the scanner to see the errors :(
Maybe next release?
Cheers
mancow
N.E. Kansas
I thought it was the two programs being open that did it but apparently it's not.
Sorry Gommert, I didn't see this post until now. I will email you with whatever information I can provide.
STiMULi
Tucson, Arizona
Tell us here too so we can keep up with the bugs, fixes and work-arounds.
Thanks!
