I received the caps and modified two speakers. The first was a Speco 8ohm speaker in a fairly large enclosure. That worked pretty well, so I did a Motorola RSN4001A next. I had to wire the cap into the speaker wire as I couldn't find a way to open the enclosure without breaking it. It sounds pretty good, but I found out afterwards that it's a 4 ohm speaker. As it happens, I have a 4024A, which is 8 ohms. I'll test the 4001A in my truck and if I don't like the sound, I'll modify the other one.
In that case, go for it.
One caveat: I'm assuming your speakers are 8-ohm. If they are some other impedance, the capacitor value has to change accordingly. For a 16-ohm speaker, a 50uF capacitor (47 being the closest commonly available value) would be the correct value. For a 4-ohm speaker, you'd need a 200uF capacitor.
