AWIN Discussion
bubbaearle
I’m trying to listen to the Logan County Sheriffs Depsrtment also but can’t find the frequency. Can you help me out?
AWIN
TGID 53885 Sheriff
TGID 18801 Emergency Services
What radio do you have??
bubbaearle
If you update the database, it'll be in there and you should pick it up as long as you have it programmed correctly.
03msc
RF is RF
The Natural State
Update the database. Set your location by zip code. Set the range (something low like 5 miles is fine, trust me). Make sure law dispatch service type is selected. It should pick it up assuming you're in range of the AWIN sites they are operating off of.
Smitty62
Magazine Ar 72943
Thank you very much!
Magnetsteve
Central Arkansas
You will need a P25 trunking capable scanner if you do not have one already. Newer talkgroup ID so it is probably operating in TDMA unless they have some older radios they are using in FDMA.
From the database:
"Logan Co has ceased using DMR in favor of AWIN"
53885d27dD42-LOGAN SOSheriff Dispatch
EDIT: I posted this reply, but the other replies to this post did not populate until after I had submitted. My bad.
drbeede
Gatewood,Missouri
From the database:
As of 12/15/2019, new AWIN radio IDs are issued only for qualified P25 Phase 2 (TDMA) radio models only. (Source ADEM) There are still some older P25 Phase 1 FDMA radios in use on the AWIN system, no timeframe has been given when these will be replaced.
bubbaearle
Is that the reason for out of sequence TGID's as opposed to new ones continuing the early ranges set for the counties?? Surely someone has lost understanding of the intent of the original TGID assignment scheme. It's become a hodge-podge in the 53xxx range.
You'd think it logical to stick to the original convention just to keep track of the counties with larger number of TGID's.
But, what do I know? I'm just a taxpayer.
drbeede
Gatewood,Missouri
I have no idea their reasons for how they now assign talkgroups, I personally think it would have been easier to keep them in some kind of logical order as well. As for all the new talkgroups they are all P25 Phase 2 (TDMA) capable talkgroups, even if they are not currently listed as such in the radioreference database, all old P25 Phase 1 FDMA radios and consoles will eventually be phased out which will improve the overall performance and capacity of the AWIN system.
Magnetsteve
Central Arkansas
Oh, I am fully aware. I am a full-time subscriber to the system in two different capacities as well as avid listener. All new talkgroups operate in TDMA unless a subscriber affiliates in FDMA. The system operates in DDM for now. I doubt they will force anyone out at this point as far as FDMA is concerned.
jhsands
Texarkana, Arkansas
There is a reason, but I don’t think it is a good one. Remember that an entire committee approved it.
k5kvn
NW Arkansas
Anyone know who these radio IDs belong to? Heard briefly on TG 52819 NW Mutual Aid 3:
802130
801972
802275
801911
bubbaearle
Catching a good bit of encrypted traffic on 53790 here in White Co. on the Floyd tower.
53789 is Springdale FD - Washington Co.
53792 is Vilonia PD - Faulkner
Leads me to suspect its a Faulkner Co. agency
wbswetnam
DMR-istan
Faulkner County Sheriff Dispatch has flipped again from talk group 19404 back to 19402. They've done this several times now. In my scanner, I just keep 19402, 19403, and 19404 all simply labeled as "Sheriff".
03msc
RF is RF
The Natural State
Interesting. Wonder how they have them labeled in their radios? And wonder why they would switch around? Interesting...
55Edward
They are labeled as follows
FCSO-1 (Typically dispatch 1) 19402
FCSO-2 (typically dispatch 2) 19403
FCSO-3 (Transport channel for the jail) 19404
FCSO-4 (Rural depts. ex. Mayflower, Guy, Greenbrier etc) 19405 Usually says unit number to Greenbrier so a mayflower unit may say 107 Greenbrier then conduct whatever traffic they need to talk about.
Hope this helps!
wbloss
Human
Joplin MO
802130 has been heard on TG 3071 Benton Co SO A
801972
802275
801911 has been heard on TG 3067 Benton Co SO C
55Edward
Faulkner County Sheriff does have a few Tac and Swat channels. I will monitor some more to see if i can get any audio or information on these and update them in the database. I will compare radio ID's as well to verify and make sure. I know that Faulkner County was supposed to be getting more Talkgroups as well as some Fire depts. moving to either CWIN ( one dept has) and AWIN.
bubbaearle
I'd bet the encrypted traffic is law enforcement of some sort. Best way is to catch radio ID's over a long period of time to track users paired to TGID's to pinpoint agencies.
I have my WS 1098 that runs constantly to do just that task. I'll go thru as see if I can export a data table that can be sorted in Excel.....won't be until the weekend tho!!
