Baofeng Baofeng DR-1909 Question
yahya
It seems that the DR-1909 started circulating on the web. Allegedly it supports DMR Tier 2 in UHF rather than FM. Has anyone more details on this radio, its compatibility with MotoTRBO, the cable that works and software programming? Does it support dual FM and DMR operation?
Whiskey3JMC
Don't feed the squirrels
Simulcastylvania, TE
N4KVE
PALM BEACH, FLORIDA
The description says “Compatible with Digital And Analog Systems”. What do you think analog is? AM? But hey, it’s got a flashlight.
Product Characteristics:
Flashlight
≥3km of Range
199 channels
MOTOTRBO Tier 2
Crystal Clear Call Quality
Dual Band Repeater
UHF 400-470Mhz
2800mAh High Capacity Battery
High Power/Low power(5W/1W)
21CM Dual Band Antenna
8-Level Stepped Frequency Selection
14 hours usage time,up to 30 hours of standby time
Emergency Alarm
Auto power saving function,Super-Long Standby
Individual/Group/All Call
Walkie-Talkie Detection
yahya
Thanks guys. But has anyone such a radio? I wanted to cross-check the specs with a real item since Chinese radios' descriptions are sometimes inaccurate. There is no information provided on programming software and cable.
By the way, Baofeng's website mentioned another version of the DR-1909 with the U letter at the end. It appears like the analog BF-1909, which can be programmed with Chirp. I presume that the DMR version rather needs a dedicated USB cable and custom software.
Check below.
RetroZander
I know this is an old post but I also had the same question, and also had a heck of a time trying to find software to program this model as it does NOT work with chirp & is not listed on the Baofeng website.
Now that I own this rig, it does do either digital or analog but it does NOT seem to do both DMR & FM (like my AnyTone does). It programs similar to other commercial UHF DMR radios. When setting up channel data, you select either DIGITAL or ANALOG first which changes the settings options.
The software for the DR-1909 is archived here (for now). If you use it, please save it somewhere safe & help to archive it somewhere for others if it gets removed.
Baofeng DR-1909 A6( AES 256) CPS : Baofeng : Free Download, Borrow, and Streaming : Internet Archive
